2000 Intake manifold gasket replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-17-2007, 06:19 PM   #1 (permalink)
View kemp215's Photo Gallery
Anyone give me any good tips on replacing my intake manifold gasket. I have a vacume leak in that gasket and it has caused my CEL with a misfire code.
Also...in the last couple of weeks my city gas mileage has decreased huge. On the hiway i get 800 km per tank..in the city its only 400km.
any tips on that?
kemp215 is offline   Reply With Quote
Old 12-17-2007, 06:38 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
I presume you have a 4banger then considering the gas mileage that you're getting?
just take it apart and replace the gasket. the v6 gasket is a lot more work to do.
HaHa
Old 12-17-2007, 06:41 PM   #3 (permalink)
ya its a 4cyl
Old 12-17-2007, 07:10 PM   #4 (permalink)
any ideas on whats causing the horrible gas mileage?
Old 12-17-2007, 09:51 PM   #5 (permalink)
TN Pussy Man
no idea....it could be a whole lot of things
but if you're still getting 800km per tank on the highway, then I don't really see the problem...sounds like you're spending a lot of time idling and eating gas that way then
HaHa
Old 12-18-2007, 06:33 AM   #6 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Don't know how many miles on the car or when it was last serviced but if you're taking the intake off consider removing the injectors while your in there and getting them tested and cleaned. There should be companies in Canada that you can mail them to for this service. They'll do flow testing before and after, clean, and replace any parts you may need.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 12-18-2007, 08:33 AM   #7 (permalink)
Former Toyota/ASE Master
Qslim's Avatar
View Qslim's Photo Gallery
Well, if you have a vacuum leak bad enough to cause a misfire, then the computer will have the fuel trim pegged as high up as it will go to try and compensate for all the extra air. A lean-running engine is not a good thing. You should replace the intake manifold gasket (if you are sure that is where the problem is) as soon as possible.
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline   Reply With Quote
Old 12-18-2007, 02:04 PM   #8 (permalink)
Thanks for the heads up...I plan on replacing in withing a week or so....although i have been running it for a few months with it like this. It took a while for the smoke test to show the leak.
Why is a lean running engine not a good thing?
also, thanks for the help guys...this site is great.
Old 12-18-2007, 02:52 PM   #9 (permalink)
Qslim's Avatar
Well, fuel mileage for one, as you've already experienced. Another concern from a lean-running engine is the heat associated with burning all that extra air. A super-lean engine can burn valves, spark plugs, and overheat the cooling system in general.
-- Get him, boy....
Old 12-18-2007, 03:07 PM   #10 (permalink)
Thanks Qslim.
Removing Intake Manifold? UWtoyo99 1st Generation (1995.5–2004) 6 09-13-2007 07:34 PM
Better Intake Manifold TTercel Tercel, Paseo, Starlet, and Sera Forum 18 01-24-2007 11:39 AM
OOPS!!! Sripped an intake manifold bolt! green94camry 3rd & 4th Generation (1992–1996 & 1997–2001) 2 10-14-2006 03:43 AM
Valve cover / Intake manifold NIXmx Camry & Solara Lounge 2 02-15-2006 03:36 PM
Continuation of my 1MZ-FE thread... New pics of the intake manifold Tony the Tiger Show & Share 54 04-30-2005 03:55 PM
