Inner Axle bearing replacement - V6/92 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-17-2007, 08:23 PM   #1 (permalink)
View backerman's Photo Gallery
USA Inner Axle bearing replacement - V6/92
Have a Camry 92 V6 and pulled the axles (both outboard boots are gone). Axles are GKN.
When I did the passenger side I noticed that the inner axle's bearing is pretty much gone. So, I took the inner axle out.
Has anyone replaced the bearing on that axle?
After some research the inner axle is not available as a reman part unless I replace the full axle. (Just done the half CV joint). Toyota told me:
- new: about $400.00
- but we also found that one gets the bearing as a spare part, and the 2 dust covers.
But, you need to get the 2 dust covers off before you get to the bearing and to do that the book tells me using a press and an SST.
Anybody with any experience for this procedure?
Not sure how to go about it. Can it be done?
Thanks for all the the thoughts and help!
backerman is offline   Reply With Quote
Old 12-17-2007, 08:46 PM   #2 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
There's a special driving tool you need to have in order to remove the one side of the CV shaft if I remember correctly. It's a royale PITA, I would just recommend getting the new axle for that side, but if you really want to go for it, by all means, go for it.
BlueFusion6851 is offline   Reply With Quote
Old 12-17-2007, 09:09 PM   #3 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
on my 4-cylinder drivers side axle, i had to re-use the dust shields. the axle i bought from napa didnt come with them. it was an easy thing to do. i used a screwdriver and hammer to work the old one off (slowly working my way around as not to distort it) and reinstalled it by placing a small block of wood against the shield and hammering that by slowly working around in circles. it didnt even take 5 minutes to do.
Axle replacement, bearing diagnostics nathan.chase Archived Corolla threads 12 01-30-2011 08:37 PM
front wheel hubs bklahl Archived Corolla threads 3 02-06-2007 09:21 PM
Wheel Bearing Replacement in 2 hrs. HELP? Xaotic 89 89-95 Toyota Pickup/Hilux 3 02-05-2007 05:17 PM
92 V6 Rhd Axle Removal Mechanic 3rd & 4th Generation (1992–1996 & 1997–2001) 8 05-14-2006 08:56 PM
bearing replacement jdm Camry & Solara Lounge 0 10-03-2003 07:59 AM
