98 camry Starter install problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-18-2007, 08:47 AM   #1 (permalink)
View robjen1019's Photo Gallery
Ok, 98 Toyota Camry install. Ive done a few of these installs on other vehicles, so when a friend asked me, I said I would give it a try.
I connected everything to the harness and car starts, but keeps activating the starter . It is supposed to have a voltage sensing unit, but seems to be not working right. So I am going to connect the tact wire.
Directions say that I can connect under the hood to a gray, or black wire. But what I am wondering is if there is a tact wire somewhere under the dash so I don't have to go through the firewall.
Next. Do the 98's need to have a key sensor connected? and where is that. I noticed that there are 3 plugs going to the ignition. Big plug(power) then two little ones. Each of which has 2 wires going in. One has blue wires the other Black. Are these key sensing, or do I not need to worry about them.
Thanks.
robjen1019 is offline   Reply With Quote
Old 12-18-2007, 09:09 AM   #2 (permalink)
Which engine? I4 or V6?
Look up online wiring diagram in repair manual ....starting section:
http://www.camrymanuals.com/index.ph...=107&topicid=0
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 12-18-2007, 11:32 AM   #3 (permalink)
I believe 4 cyl
GPS Antenna Location on Gen 6 hybridamp 5th & 6th Generation (2002-2006 & 2007-2011) 2 08-30-2006 12:13 PM
Toyota's Globalization Takes Shape through the Camry 2007CamryXLE 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-19-2006 06:52 PM
Toyota Camry Generations spdlva2nv4eva Camry & Solara Lounge 0 08-10-2006 11:45 PM
98 camry xle aftermarket deck install 98camryxle 3rd & 4th Generation (1992–1996 & 1997–2001) 6 03-27-2005 05:56 AM
remote starter install problems koss78a Archived Corolla threads 1 11-19-2004 09:28 PM
