Hate to bring a thread from the dead, but this is the same exact problem in the 1999.
Was a recent purchase with about 63K on the odometer. Highway driving, the temperatures would not raise past about 1/3 or so. In traffic, it idled normally just under half, but upon driving, it would drop back down again. It was reminiscent of a modification I had done to a previous car, so I decided to check the thermostat. Just like the OP, there was no thermostat. I installed one and let the car .... and the fans refused to turn on.
As the engine temp soared, I wondered if it was the fans themselves or something else electrical which I hate. I decided to pull full load on the motor by turning the a/c on, and both fans worked! So with the blower motor on, either on fan or on a/c, both fans work and the car works fine (fans cut in and out at the correct temp, even on idle) but with the blower motor off, the fans never work at all.
At first I thought coolant temp sensor, but why would it fail with the blower motor off but work just fine when the blower motor is on? Also, I thought about the relay but would the fan work at all if it was faulty relay? I'm stumped .... help please!
