EGR and ABS problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-19-2007, 12:04 PM   #1 (permalink)
View slomo_01's Photo Gallery
EGR and ABS problem
I have a 98 Camry the check engine light came on, I had it read and it was and EGR insufficeint flow(p0401 I think) Does anybody know what the likely cause of this is? I have heard both that it is normally the EGR valve or its normally the VSV.
I also got an ABS light that just came on. It came on after I parked on a bunch of leaves and sticks. I checked inbetween the sensors and nothing was there? Does anyone know what their resistance should be? Or what I should check? Any help would be great. I'll tell ya if I find any thing. Thanks. Slomo
slomo_01 is offline   Reply With Quote
Old 12-19-2007, 05:26 PM   #2 (permalink)
Former Toyota/ASE Master
Qslim's Avatar
View Qslim's Photo Gallery
For the EGR, the vacuum switching valve on the back of the block are common culprits, but I wouldn't jump to replacing it until you looked over the vacuum hoses and the make sure the EGR valve and ports in the intake manifold are clear.
For the ABS, I got your PM and code 36 is "open circuit in left front wheel speed sensor circuit". Pretty cut & dry, the computer is telling you that it isn't getting any kind of signal from that corner. The easiest way to verify this is to unplug the connector (up in the wheel well, the wire runs from the wheel up the strut and then onto the frame) and put a meter on it to verify you have no continuity. Replacing the thing is just as straightforward, and the ABS light will clear itself after you drive a few feet. Hope this helps.
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline   Reply With Quote
Old 08-22-2008, 05:22 PM   #3 (permalink)
View 97vulcan's Photo Gallery
I have a code 36. I thought this meant right front/left rear sensor circuit open on a gen 3 camry. Would cleaning the sensor make any difference? Also, I can't find the ABS sensor in the rear of my 1992.
thanks,
adam
Mine:
1992 Camry LE 5sfe 128,000 miles
1998 Ford Contour SVT 148,000 miles(SOLD)
Wifes:
1994 Camry LE 5sfe 224,000 miles
97vulcan is offline   Reply With Quote
Old 08-23-2008, 12:03 AM   #4 (permalink)
Qslim's Avatar
thanks,
adam
Yes, your Camry is listed as front right/rear left, so you'll have to check both. Take the wheel off and look on the steering knuckle, it's the only thing on there with a wire attached to it.
-- Get him, boy....
Old 08-23-2008, 10:27 AM   #5 (permalink)
I now have a code 34 and 36. Does this shed any more light on the problem?
Adam
Mine:
Wifes:
Old 08-23-2008, 12:15 PM   #6 (permalink)
Qslim's Avatar
Yeah, 34 narrows it down to the rear left corner specifically, so you should have a good idea where your problem is now.
-- Get him, boy....
Old 08-23-2008, 12:46 PM   #7 (permalink)
good to know! is there anything I should be looking for when I take the wheel off that side?? Could the sensor be dirty?? or is it usually something more.
thanks,
adam
Mine:
Wifes:
Old 08-23-2008, 04:39 PM   #8 (permalink)
Qslim's Avatar
thanks,
adam
You'll most likely be looking for a broken wire or an open coil inside the sensor. Unplug it, check to see if you have continuity across the terminals.
-- Get him, boy....
