turn signal prob - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-19-2007, 12:38 PM   #1 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
3rd Generation turn signal prob
my left turn signal doesnt work. i have no idea what happened. my right side works.. but not the left side... it also works with the hazards on...
any ideas???
any help please!!!
94 XLE 3.0
Old 12-19-2007, 04:38 PM   #2 (permalink)
sexy, dirty, and slow...
93XLEcamry's Avatar
View 93XLEcamry's Photo Gallery
the same happen to my gf car...i dont know what is wrong with it also....her signals both doesnt work, it doesnt even make that clicking sound anymore...help ppl...lol
93XLEcamry is offline   Reply With Quote
Old 12-20-2007, 09:05 AM   #3 (permalink)
View 1996camry's Photo Gallery
get a meter measure the voltage to see if u get any at all when u turn the left signal? take the light buld off and measure the voltage...
possible u have bad relay(signal)...try that first then see if that help..
1996camry is offline   Reply With Quote
Old 12-20-2007, 11:11 AM   #4 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
I believe that the same circuit is used for the flashers as the blinkers. If that is the case I would think that your problem is with the switch on the steering wheel or the wires going from the switch to the relay. I'm not positive but I think that the fact that it works on the flasher system exonerates everything from the relay back to and including the bulb.
Kep
Old 12-20-2007, 04:29 PM   #5 (permalink)
View joandjo's Photo Gallery
I had the same problem a couple of years ago. It turned out to be the contact point in the switch worn out. I replaced the entire combination switch. It was not that difficult if you can take out the steering wheel.
1992 Toyota Camry LE, 3vz-fe, 254K mi, still going strong...
joandjo is offline   Reply With Quote
Old 12-20-2007, 05:29 PM   #6 (permalink)
EvoFire's Avatar
View EvoFire's Photo Gallery
Sorry no help here. My signals broke once, it won't work at all, left or right, I turned my hazards on and off and it worked again. Little electric gremlins.
EvoFire is offline   Reply With Quote
Old 12-24-2007, 01:07 AM   #7 (permalink)
93XLEcamry's Avatar
sorry for the so late reply, but thanks for the inputs....does it cost much to get it repair??
Old 01-02-2008, 05:09 PM   #8 (permalink)
Good idea i will try to measure the volts later
Thanks
Old 01-02-2008, 05:14 PM   #9 (permalink)
i was thinking the same thing about the flashers and blinkers is on the same circuit.
ok my left doesnt beep(clicking noise) or whatever when i put on the left blinker
i got to try measure voltage later and i'll get back with results
thanks
Kep
Turn Signal Volume tacomatom 2nd Generation (2005+) 16 04-03-2009 05:05 PM
strange turn signal problem 91 corolla billsif Archived Corolla threads 3 08-21-2006 01:47 AM
Left Turn Signal nitu_752002 Archived Corolla threads 4 06-30-2006 11:06 AM
signal indicator prob. thundermaker32 Archived Corolla threads 9 01-21-2006 02:41 AM
Side Marker Turn Signal Mod JPR94 Camry & Solara Lounge 4 12-11-2003 11:26 AM
