How did the subframe take a beating changing the steering rack out? And I'm having a hard time believing that you had to buy a whole new rack to replace the rack bushings. usually you can order the bushings from Napa, and just press them in. Of course, this involves more labor than just changing the rack, and pays a lot less, so now at least we know why you replaced your entire rack...
I would make your mechanic show you exactly where the remaining play in the steering system is, why the subframe needs to be replaced, and how it got "beat up" in the process of changing a steering rack. The most i've had to do with a subframe while changing a rack is lower it enough to allow the steering gear to slide out. I smell BS.
As far as changing the subframe, the part should not be that expensive, and it's not really that difficult to change, but without the proper lift/support equipment it can be risky. Let us know what happens!
'96 4cyl 5spd Camry
147k miles and running out of things to fix...
