Originally Posted by turbocamry44
some questions for you smart guys
1. what should the nomal egt temp be for 5sfe.
2. when running safc on 5sfe first can i and second anything special to know
thanx abunch
EGTs are tricky....as 88LE said first dial in you A/F ratios and then your EGTs shoudl fall in place.
The SAFC shold have no problem running on the 5SFE just make sure you know all the correct wires that you are taping into or cutting. I would advise on picking up a Harness Patch from
www.autosportwiring.com so that you can wire it into that on your workbench and then make it a real plug n play application.
