Need Help Adjusting Projectors - w/ Pics! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-20-2007, 01:20 AM   #1 (permalink)
View flamerid's Photo Gallery
3rd Generation Need Help Adjusting Projectors - w/ Pics!
Please help me adjust these projectors. These are TSX projectors on a 1996 Camry LE. I've only done one headlight...what I've done so far is try to aim it towards the center of the car level with the projectors position on the car - using the center line here:
..........______..............
_____/...............
I'm also not sure if the projectors are in far enough. So I'm open to any thoughts on the position.
I have some photos. The car on a sloped driveway so it was a little tough. I was about 9 feet back when I took these pictures. The cut off line was about 1 foot, 10 inches off the ground. Also, it was raining outside...I know, I'm mad. Cheers.
Please excuse the cruddy camera and poor lighting.
- also posted on hidplanet
flamerid is offline   Reply With Quote
Old 12-20-2007, 01:55 AM   #2 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
im not entirely sure, but arent u supposed to adjust them using a 20-foot distance or something like that?
if you get too close (or too far, for that matter) your adjustments will be useless
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 12-20-2007, 02:12 AM   #3 (permalink)
mox
God Machine
mox's Avatar
View mox's Photo Gallery
Adjusting is a hell.. this is what have been slowing down my projector retrofit for about a year.. lol
Eh, I was going to suggest you to take a look at hidplanet but I see that you have posted there
http://www.hidplanet.com/forums/viewtopic.php?t=38274
I'm pretty sure they will have the answer for you!
Good luck with your project, dont' forget to show us the result when you're done!
'92 Camry SE V6 5 Speeds (Pics: 1 | 2 | mox.monchar.com) ('06-now)
Previously owned: '99 Corolla,MT ('99-'01), '97 Camry XLE V6,AT ('01-'02), '92 Camry SE V6,MT ('02-'04), '99 Solara SE V6,MT ('04-'06), '93 Camry LE V6,AT ('06-'07)
mox is offline   Reply With Quote
Old 12-20-2007, 08:12 AM   #4 (permalink)
Nobody ever replies to my topics at hidplanet...I don't think I'm going to get much help there. I'll try to take your advice and compare to other pics I see online. I just wish they had better specific specs online like 10ft away and 2ft high on the wall.
Old 12-20-2007, 09:21 AM   #5 (permalink)
bitch please
DarkMastyr's Avatar
View DarkMastyr's Photo Gallery
Looks like your rotation and height are just fine. I wouldn't necessarily aim the step at the center of the car though, since you'll decrease the width of the beam if you do that. Space it from the center for better width. In the end, you should get a beam pattern that looks like this:
..........______.._________
_____/.........../
If you think it's not recessed enough, just see if the cover will fit back on. As long as it does, you're fine. Drill a bigger hole if necessary.
Make sure you put a bezel of some sort on the projector. Otherwise it'll just look like crap.
1994 Camry 2.2L LE Auto
DarkMastyr is offline   Reply With Quote
Old 12-20-2007, 10:51 AM   #6 (permalink)
I just went and adjusted it from a wall 20ft off and I tested close up as well..it doesn't change the height as I move from it so I guess I have a nice level beam.
Also, I see what you mean DarkMastyr. When I was adjusting it I thought it was a bit funky. In the end I came up with a pattern like the one you explained. I think that should be pretty good.
As for the bezel...do you mean shrouds? I have some MDX ones if that's what you mean.
I plan on painting the low beam side of the headlights black. Any tips on how to do this correctly or how much I should paint?
Old 12-20-2007, 11:25 AM   #7 (permalink)
bitch please
DarkMastyr's Avatar
If you're going to paint, just use blue painter's tape to mask off sections that you don't want to be sprayed, and you need to paint while the projector is out, so do it now before you make any more adjustments. Otherwise you'll have to make them all over again.
As for bezels, I mean some sort of ring to cover the front of the projector. I usually refer to shrouds as some sort of cylindrical cover (like a coke can) to block any excess light coming out of the projector, but since TSX projectors are enclosed, they're not really necessary. Just a choice of words.
E46 bezels...
I'm assuming you have these then...
Old 12-20-2007, 11:54 AM   #8 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
Headlight Adjustment
CAUTION: Headlights become very hot during use; do not touch them or any attaching hardware immediately after they have been turned off.
Before adjusting the headlights:
  • Park the vehicle on a level surface.
  • Make sure the tire pressures are correct.
  • Have the driver or someone who weights the same sit in the driver's seat.
  1. Clean the outer lens so that you can see the center of the headlights.
  1. Park the vehicle 25 ft (7.5 m) away from a wall or a screen (A).
  2. Turn the low beams on.
  1. Determine if the headlights are aimed properly. Vertical adjustment: Measure the height of the headlights (A). The lights should reflect 52 mm (2.1 in.) below headlight height (B).
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 12-20-2007, 05:41 PM   #9 (permalink)
EvoFire's Avatar
View EvoFire's Photo Gallery
I guess from what JSm posted, the cutoff should be the same height as ur headlights.
That's sick man, I was planning to do that.... Looking forward to the finished product
EvoFire is offline   Reply With Quote
Old 12-20-2007, 06:39 PM   #10 (permalink)
JSM1284's Avatar
Actually, 2.1 inches below the height of the headlights at 25ft away.
2005 Lexus ES330
POST PICS Of Your Corolla Here! REN69 Corolla Lounge 0 09-09-2007 09:36 PM
56K :( TRD body kit pics and new gauges (large pics, but that is fun...) Hamsterman Camry & Solara Lounge 57 10-10-2005 06:14 PM
For Sale: 1991 Toyota MR2 non-turbo automatic (many pics) LarryDallas Vehicles 2 07-07-2005 03:15 AM
Pics, Pics Pics . . . Hooray ! 92CleanCam Camry & Solara Lounge 38 10-17-2004 07:25 PM
subforum for pics DrtySthV6SE Site Suggestions, Questions, and Comments 8 10-14-2004 09:22 PM
