Rear defroster won't work need diagnosing assistance - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-20-2007, 02:50 PM   #1 (permalink)
View steppinthrax's Photo Gallery
I have a 99 Camry LE. I noticed when it started getting cold the rear defroster didn’t work. I would push the button and it would light (indicator), but I can tell it doesn’t work. I have the Factory Service Manual. I went though the diagnostics but the only thing it leads me is something is wrong with the wiring from the relay (switch side) to the actual defroster coil.
I’ve done the following
1. Tested the switch (works)
2. Tested the relay (works clicks when switch pushed)
3. Pulled off molding on rear window and checked coil. Coil shows resistance and works, no damaged lines.
The I pulled off the wires that run to the defroster coil. I’m getting no voltage to the defroster coil. Which tells me something is wrong with the wiring that leads to the defroster coil.
Does anyone know any other ideas?
steppinthrax is offline   Reply With Quote
Old 12-20-2007, 03:48 PM   #2 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
Even if the relay is clicking, It may not be providing a closed circuit. Test voltage from the relay.
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Brake Noise FirstCamry 5th & 6th Generation (2002-2006 & 2007-2011) 7 10-30-2007 02:40 PM
Wiring connection for the rear window defroster chipmckcmo Archived Corolla threads 0 10-02-2005 10:20 PM
Need SC300 rear bumper and body work altatensio General Lexus Discussion 1 09-03-2004 08:14 PM
rear window defroster kuli48 Camry & Solara Lounge 1 12-13-2003 08:14 PM
Drift Setting help for GT3 I hate Toyota Corp :( Off Topic 3 11-10-2003 10:36 PM
