Originally Posted by number73forlife
If your car is LE or CE model trim then you 99.999999% have drums in the rear. Disks were $2000+ option with abs. Pads should be low dust / dust fee especially if you have aftermarket wheels to minimize corrosive contact with brake dust. Blanks are blanks as long as they are made of quality material. Only differentiation appears when considering slot'd and drilled.
Some slot'd rotors are good but are unneccessary if you are not doing lots of hill driving or aggressive daily like motor crossing etc. Drilled is asking for problems. Only company that has a clue how to make cross drilled rotors is Porsche. They actually cast the rotor with the holes in it. Other companies take blanks and drill them after forming and that structurally comprises the rotor and makes them very prone to cracking. And cutting a rotor?? Sounds like poor quality product and fitment issues to me.
Brake fluid is brake fluid so long as you are not aggresively driving and doing lots of hills again because higher temp will make them less likely to boil and fail.
General rule of thumb is stick to OEM if it worked before.
Well, I have used BREMBO blanks for many makes and instances. Only in 1 situation did I have to cut it for the sake. Oh well
In all the other times it was fine, no weird noise, nothing.
I do believe in OEM, but I just prefer something better if it's worth it. I don't drive aggressively but I sit in quite a lot of traffic at times.
*btw, does changing plug wires matter?
thanks.
