My typical "Clunking" front end experience with solutions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-22-2007, 09:29 PM   #1 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
4th Generation My typical "Clunking" front end experience with solutions
So, I have a 1997 Toyota Camry LE V6. It has the typical clunking that occurs on most Gen4s. Mine is at 120k miles or so. I have replaced the struts with KYB GR-2s and still running on stock springs. The clunking has been coming from the front and many say its the strut mounts.
So what I did was order OEM strut mounts and just swapped it out. I ended up breaking a sway bar link in the process, but it was fairly easy to do. All I needed was a strut compressor and bam, it's done. The strut mount replacement actually did solve my problem.
The clunking is typically louder in the winter time, but I've had it done for the past few weeks and it works great. No more clunking and the steering itself does feel a bit smoother with the struts being able to rotate more freely.
All I would recommend replacing at the same time is the strut bearing plates thats directly underneath the strut mount. I forgot about them and didn't buy any. But for those who want to fix that annoying clunking sound, I vouch for the strut mount replacement.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 12-23-2007, 02:45 AM   #2 (permalink)
View yeskay's Photo Gallery
does it require alignment after the strut mount replacement? can you do it yourself.
Thanks
yeskay is offline   Reply With Quote
Old 12-23-2007, 06:25 PM   #3 (permalink)
2GR FTW
darksparkz's Avatar
Yeah, it does require alignment. Realignments are usually better done with a mechanic because they used computertized alignments, but its somewhat possible to do it by hand following the manuals for the proper settings.
Lexus IS Pricing (Canada) lexusis350 Toyota News 28 10-01-2007 11:30 AM
Whiteline MA70 Front/Rear Adjustable Swaybar GroupBuy!! raptorracing Supporting Vendor Sales 30 04-27-2007 03:27 AM
ae92 usdm front end for sale corollaguy86 Car Parts for Sale 1 02-20-2007 01:16 AM
Susp. mods - Front End Noise is Gone dj14901 Camry & Solara Lounge 10 07-01-2006 05:49 AM
Front End Mask/Bra ChristCorp Camry & Solara Lounge 6 07-14-2004 12:02 PM
