Looking at the 'Light Auto Turnoff' diagram, p. 112, Gen 3 online repair manual, there is a part labeled 'Door Courtesy Switch Front LH' which would control the headlight turnoff function.
This switch is shown to be located in the driver door closure area ... see part D12, on p. 34 of manual pdf .... so that it activates as the driver's door is opened. It is possible that this pin switch is not making good electrical contact, due to debris, dirt, or corrosion. If you can locate this switch and spray it with some electrical contact cleaner, it might start working. If that doesn't produce a result, you might have to disassemble the switch, clean it thoroughly, and check for functionality. ... Although, the problem which you describe might be associated with the Integration Relay ... an electronic integrated circuit type of part, it is most likely that the difficulty is the door switch.
... Not sure about the interior light function ... may be related to headlight problem.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
