Originally Posted by trninhds
once you knock out the old studs with a hammer, use a couple of washers and a open ended nut, once its on hand tight, an impact gun until the knurl end of the lug stud is flat against the hub. Its really easy to do
And if you don't have an impact, a large ratchet or breaker bar will work. Just takes more time, and you gotta hold the hub still with something.
And using an air impact to put wheels on only does damage if you do it wrong. Unfortunately about 70% of the people who use an air impact do it wrong...
