E-Brake Wire - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-23-2007, 04:34 PM   #1 (permalink)
View thaFranchize2b's Photo Gallery
4th Generation E-Brake Wire
Hey I have an In-Dash DVD player that Im looking to install and it has this pink wire. In the instructions it says to hook up to the Emergency Brake... thing is I Don't know where to find that in a 1998 Camry and I can't just ground it
So if anyone knows where to plug that E-Brake wire up to it would be appreciated thanks
thaFranchize2b is offline   Reply With Quote
Old 12-23-2007, 04:36 PM   #2 (permalink)
View karl_karl's Photo Gallery
ground it
I just installed a Jensen in dash dvd for my gen 3 camry and i just coupled the pink wire with the black wire and grounded them both, no issues thus far.
You need to ground it somehow to get the dvd player to play movies.
karl_karl is offline   Reply With Quote
Old 12-23-2007, 04:40 PM   #3 (permalink)
hey thanks for replying man. What black wire are you talkin bout, cuz I have a Jensen too
Old 12-23-2007, 07:00 PM   #4 (permalink)
'00 V-6 Camry's Avatar
View '00 V-6 Camry's Photo Gallery
4th Generation
that wire is so you can only play movies while your stopped i would just ground it some where not to the e brake the black wire should be right next to the red one on the jensen head unit
FloridaBoy lost in North Dakota
'00 V-6 Camry is offline   Reply With Quote
Old 12-23-2007, 10:09 PM   #5 (permalink)
Radio, this is Unit 91...
eurohazard's Avatar
View eurohazard's Photo Gallery
^ Exactly! I laughed my ass off when I learned some aftermarket manufacturers were using a wire to tap into the E-brake. This would insure that only "parked cars" could play movies! OMFG. As a few of you have figured it out, all you need to do is ground that wire, and you're good to go.
Pioneer got tricky though by using the GPS signal (in their high end units) to sense if the vehicle was in motion....and if it was, the DVD wouldn't play on the head unit. Go Jenson Go!
1993 Camry LE 5SFE AT, 2006 Nissan Armada LE 4x4, 1971 Cadillac Coupe DeVille "pimp juice"
Toys: 2007 Coachmen 19FLB, 2007 Regal 1900 V6
I'm the biggest boss thatchu seen thus far! Baby, that's muh wi'zzard!
eurohazard is offline   Reply With Quote
Old 12-24-2007, 01:27 PM   #6 (permalink)
yeah it is a joke...apparently some jensen decks smartened up and you can't just ground it...you need to input some whacky code...i just tried grounding mine and it worked
the model is VM8012 and you have to join the pink wire with the Black GROUND wire that is outlined in your owners manual.
Old 12-24-2007, 02:34 PM   #7 (permalink)
Do you know anything about a Jensen VM9311TS? Its an older model but there is a code you can put in to Bypass the break so you dont need to ground it or use a pulse switch or anything. Thats why I was gonna just hook the E-Brake wire up how it is supposed to go, and just input that code so I dont have to ground anything
but I dont know where that E-Brake wire goes
Official SMT-6 piggyback install guide for 3vz-fe's Toysrme Camry & Solara Lounge 9 10-12-2010 02:28 PM
brake lines and struts - 90 Corolla freakboy25 6th Generation (1988-1992) 6 11-22-2007 08:09 AM
AE92 & AE82 Brake upgrade options.... freakinbox Older Generations (1969-1987) 8 09-13-2007 03:41 AM
HID question CamNub 5th & 6th Generation (2002-2006 & 2007-2011) 13 09-05-2007 06:50 PM
Possible to Wire Brake Lights to a Switch? tooblutacoma06 2nd Generation (2005+) 8 04-28-2007 11:19 PM
