Heated Mirrors - Project - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-23-2007, 07:22 PM   #1 (permalink)
View dug320's Photo Gallery
I really want heated mirrors. I am tired of the scrape.
As I find time I will update the procedure.
Mirror removal. Easiest trick with a factory mirror is to grasp the bottom outside of the mirror. Get your fingers behind the mirror and pull it toward the car. A factory mirror will pop.
Separate mirror from holder. Use hot tap water and heat up the outer plastic holder and gently bend the plastic rim off of the glass mirror. Start at one corner and work it around the edge. Keep the plastic hot and pliable with hot water. Patience.
Separate adhesive from the mirror. DO NOT USE ANYTHING OTHER THAN A SOLVENT. Your finger nail will scratch the coating! Use a solvent to dissolve the 3M adhesive. It will take some time. I used camping/coleman stove fuel. I poured a small amount on the mirror and used my finger to rub the solvent onto the adhesive. The backing is super easy to scratch so take your time.
Next is drilling out the holder and mounting the mirror.
dug320 is offline   Reply With Quote
Old 12-23-2007, 10:01 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
nice man. just take lots of pics
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
2000 Solara check engine light mytoyota02 Solara 25 10-16-2011 12:06 PM
FS Tundra Power Heated Sport Mirrors ungersathome Truck/SUV/van parts for sale 0 12-13-2007 09:16 PM
Turn Signal, Auto Dimming, Puddle Lamp, Heated Exterior Mirrors njerald 5th & 6th Generation (2002-2006 & 2007-2011) 2 11-14-2007 05:51 PM
Is it possible to have heated mirrors for 2007 LE V6? Barracuda 5th & 6th Generation (2002-2006 & 2007-2011) 11 01-07-2007 09:27 PM
Heated mirrors Snow White IS General Lexus Discussion 20 02-27-2004 06:52 AM
