3vz advancing timing when hot - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-24-2007, 07:31 PM   #1 (permalink)
[{} {}} =MR2 V6= {{} {}]
View Boostyle3VZ's Photo Gallery
I have a 3vz in my MR2 and Ive been having trouble for a while now. I noticed my car starting to ping and I checked my timing, I was completely off the scale. When its cold its completely fine, I can have timing set at 10º BTC but when it gets to running temp itll be roughly around ~20º. To keep a decent timing I have to have my distributor fully retarded to get to ~12º BTC when at running temp. But when its cold its down at ~1º BTC where it really should be with the distributor clocked fully retarded...
Ive replaced the AFM and TPS as Ive read both are used by the ECU to determine timing.
All I can think of now is wiring or ECU. Any ideas?
Boostyle3VZ is offline   Reply With Quote
Old 12-24-2007, 09:29 PM   #2 (permalink)
... Something to do with engine temperature maybe ... Check the resistance of the Engine Coolant Temperature Sensor ... and also the temperature at which you take the measurement .... At 70F, it should measure 1 or 2 kohms.
Are you getting any CEL codes ...
If you can access the Gen 4 Diagnostic section of the repair manual, there is a resistance vs. temp chart on p. 35
Do you have access to a scan tool?
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 12-24-2007, 09:41 PM   #3 (permalink)
no CEL. the engine is a 93 so its not OBDII. I did take it apart today and noticed the coolant temp sensor at the thermostat seemed to have come off and got tore up by my alternaot belt so I spliced on a new connector and plugged it on but its too cold to put it back together Thanks for the input and Ill let you know if that was the cause of it tomorrow.
Old 12-25-2007, 08:26 AM   #4 (permalink)
Bouncing the rev limiter
92ES5sp's Avatar
View 92ES5sp's Photo Gallery
Are you jumping TE1 and E1 when youre setting the timing to 10*?
1992 Lexus ES 300 5 Speed -My baby- 111K - Slightly modded 3VZ-FE - Denso Iridium plugs/Vitek Wires - KYB Struts & Mounts - Whiteline RSB
2000 Toyota Solara SLE V6 Auto 3100 miles on the clock (Summer ride)
92ES5sp is offline   Reply With Quote
Old 12-25-2007, 12:28 PM   #5 (permalink)
yup, every time. CEL flashes, but no codes. No problems in the wiring with that. I want to check a few more things but Im really leaning towards an ECU failure. I havent checked to see what it does when I pull the jumper out of te1 and e1 during a timing test. Itll be interesting to see if it advances or not.
91 replaced Water pump& timing belt 3sfe timings off now??? Toyotasrgreat! 1st & 2nd Generation (1983–1986 & 1987-1991) 3 08-24-2005 12:59 PM
Timing belt replacement error? 90 Gen2 Camry & Solara Lounge 6 08-14-2005 07:43 PM
timing belt replaced, now 5 deg atdc?? asm Camry & Solara Lounge 5 07-20-2005 04:22 AM
22R timing chain nightmare rddrgn1 Hardcore Tech and Competition 4 05-07-2005 11:23 AM
3vz auto timing advance? Nick Hardcore Tech and Competition 8 10-27-2003 08:23 AM
