Internal Distributor Oil Leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-25-2007, 02:27 PM   #1 (permalink)
View fabbb's Photo Gallery
Found a good part source for oil leaks from the distributor shaft seal which results in oil inside the distributor. http://www.applied.com/ pn 10X20X7TC for around $6.00 per seal. It is a 10mm shaft dia/20mm outside dia/7mm deep/tc douple lip seal. The stock seal is 5mm deep but the 7mm unit goes in and works just fine.
SteveB
fabbb is offline   Reply With Quote
Oil Pan / Leak bigblueyota89 89-95 Toyota Pickup/Hilux 8 03-25-2008 03:15 PM
can V-6 tensioner leak oil? Robert K 3rd & 4th Generation (1992–1996 & 1997–2001) 3 01-03-2007 05:50 PM
Oil Leak when Accelerating??? renmike 3rd & 4th Generation (1992–1996 & 1997–2001) 6 10-08-2006 08:41 PM
Mysterious oil leak + wierd sound.. see pictures Mins Archived Corolla threads 5 01-20-2006 11:05 PM
I have a Rad fluid leak help me Loan Wolf Cam87 Camry & Solara Lounge 8 04-30-2005 02:19 PM
