Will swapping my ecu get rid of my check engine and airbag light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-25-2007, 10:40 PM   #1 (permalink)
Camryv6xle's Avatar
View Camryv6xle's Photo Gallery
I have an extra ecu for my car and wondering if i switched it with the one already in the car if it would take away my airbag light and checkengine light from the dash thanks
http://i89.photobucket.com/albums/k205/gunit2049/0108091104-00-1.jpg
Camryv6xle is offline   Reply With Quote
Old 12-25-2007, 10:45 PM   #2 (permalink)
View 94CoupeV6's Photo Gallery
Why would it? It might clear them for a couple minutes, but it will come right back. Just fix your problems instead of covering it up.
94CoupeV6 is offline   Reply With Quote
Old 12-25-2007, 10:46 PM   #3 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
It's not the ECU thats wrong, it's the sensors on the car which send a signal to the ECU, which then turns on the CEL.
geoff5093 is offline   Reply With Quote
Old 12-25-2007, 10:47 PM   #4 (permalink)
Camryv6xle's Avatar
ohhh k thanks guys
Old 12-25-2007, 11:34 PM   #5 (permalink)
DIY : I believe
Maim Menu's Avatar
View Maim Menu's Photo Gallery
If you want to rule out the screwed up ECU (unlikely) possibility for sensor problems, try it. But if the problem is not your ECU, they'll come right back.
What codes are you getting?
Restoring '65 Chevy Impala Super Sport w/ 327-300 small block, Edelbrock carb/intake and T-5 tranny that will probably blow up.
Black '98 Camry LE 4Cyl Auto, 188 000Kms and counting
Black '98 Camry CE 4Cyl Auto, 295 000Kms and counting - SOLD
Maim Menu is offline   Reply With Quote
Old 12-25-2007, 11:39 PM   #6 (permalink)
Camryv6xle's Avatar
i don't know the codes, i have to get autozone to code me up tomorrow or this weekend it happened when i put in my gauges and tapped into a wrong wire hoping for a 12 v, yeah well i screwed up.
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-29-2008 11:33 PM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
Airbag light is on etc 3rd & 4th Generation (1992–1996 & 1997–2001) 0 05-04-2007 01:18 PM
Blinking airbag light when very cold jgayman 1st Generation (2001–2007) 2 03-08-2007 03:56 PM
airbag light (previous posts checked) boost3dsupra Camry & Solara Lounge 13 07-28-2004 01:10 AM
