1992 Camry started chiming when key is turned off - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-26-2007, 03:34 PM   #1 (permalink)
View JSolCanby's Photo Gallery
USA 1992 Camry started chiming when key is turned off
Hi,
I purchased this Camry new in 1992 and only within the past month has it started making a rapid chiming sound when the engine is shut off and even after the key is removed. It seems to continue for at least 5 seconds after the key has been removed. I can't find anything in the owners manual about warning chimes so I'm not sure just what exactly the car is trying to tell me.
If anyone knows what it is or can venture an educated guess, I certainly would appreciate it.
Thanks, Joe
JSolCanby is offline   Reply With Quote
Old 12-26-2007, 03:59 PM   #2 (permalink)
Just a guess ... possibly a dirty or stuck contact within the ignition switch.
Try getting a spray can of electrical contact cleaner .... spray the ignition switch key aperture thoroughly .... rotate key several times ....
... Worth a try maybe.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 12-27-2007, 10:37 AM   #3 (permalink)
View wellsb1's Photo Gallery
3rd Generation
I had the same issue and it was driving me crazy. It turned out to be my sunroof was opened just a little. Not enough to make any wind noise but enough to be detected and set off the warning chime.
try this
wellsb1 is offline   Reply With Quote
Old 12-27-2007, 11:26 AM   #4 (permalink)
USA
Thanks for the quick responses. dc_98_cam: I put the electrical contact cleaner on my shopping list and in the meantime I received the response from wellsb1 regarding the sun roof. Went out and checked it -- it looked closed -- but I opened and closed it and sure enough, the chiming stopped.
Thanks again for your responses.
Joe
Getting alarm to chirp procedure - here it is JJMARINE 2nd Generation (2005+) 27 07-13-2007 04:06 PM
1992 Camry CSI LTD SV21 Protaeus 3rd & 4th Generation (1992–1996 & 1997–2001) 4 06-03-2006 03:36 AM
Fusion marches past Camry! sciguy0504 Camry & Solara Lounge 38 05-04-2006 06:27 AM
My key for the camry is all worn out... strmagiceet Camry & Solara Lounge 9 02-03-2005 07:39 AM
1992 gen 3 Camry Cheap! 102,000 Ruggs59 Vehicles 4 01-06-2005 04:56 PM
