Sensors Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-28-2007, 08:52 AM   #1 (permalink)
View mdmm's Photo Gallery
Canada Sensors Problem
My Camry 2000,ce,4 cyl. is giving me 2 codes, po 441 and PO 446, evaporation emission system.Please let me know how can I fix ,clean sensor,replace sensor,fuel cap cleaning or replacing.What is exact location to find to check it.How can i check the wire connections of Catalytic Converter, please/.thanks
mdmm is offline   Reply With Quote
Old 12-28-2007, 10:23 AM   #2 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
VSV on the charcoal canister at fuel tank, above rear suspension cross arm mount.
Nothing urgent, so wait till the snow is gone.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 12-28-2007, 11:28 AM   #3 (permalink)
View toyomoho's Photo Gallery
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0446 Evaporative Emission Control System Vent Control Malfunction
The fuel tank is sealed to prevent gasoline emissions. The charcoal canister absorbs any gas fumes, stores them. The fumes are then directed to the engine to be burned when running. The system has a pressure sensor to detect if the tank remains pressured. If the tank depressurizes, the codes are tripped indicating an air leak somewhere or one of the system components is not working.
If both P0441 and P0446 check for malfunction in VSV for EVAP, VSV for vapor pressure sensor, vapor pressure sensor. Cracked or blocked vacuum hose charcoal canister leak and fuel tank overflow check valve leak.
The converter does not have any electrical connections; you may be taking about the A/F sensors. These codes are not related to the either of these areas.
Start by checking for cracked leaking hoses and a damaged canister.
2002 Tacoma 4x4 TRD Differential or Transmission problem? sailingceleste 1st Generation (1995.5–2004) 15 07-26-2007 12:14 PM
Oxygen Sensors grumpy Tercel, Paseo, Starlet, and Sera Forum 8 11-07-2005 11:46 PM
vacuum leak problem...also electrical problem related. afyouthbrigade Camry & Solara Lounge 5 11-03-2005 01:45 PM
QUICK SHIFTER/UNDER PANEL PROBLEM!! & DVD NAVIGATION??!! Rocness81 1st Generation (2003-2008) 6 12-09-2004 10:27 AM
Help! Auto Tranny problem Lilwhite Celica Forum 3 02-14-2004 01:33 PM
