How do I replace the ignition switch in a 96 Camry wagon? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-29-2007, 11:37 AM   #1 (permalink)
View Larry Cole's Photo Gallery
Hi folks,
The ignition in this car is in the dash, not the steering column. I've taken off the panel below the steering colum / dash, but can't figure out how to get at the ignition switch.
And how does the big connector disconnect? Is there a latch on it somewhere?
I'm pretty sure the problem is the ignition switch, because the car suddenly wouldn't start. I was able to get it to start by jumping the solenoid at the starter motor. But once it was running, weird electrical things were happening. If I activated the turn signal, the power locks would lock. I put it in drive, and the green transmission indicator "D" light would blink like it was a turn signal!
Then, when I turned off the car, one of the turn signals kept blinking.
So, do you also think the ignition switch is the problem, and if so, how do I replace it?
Thanks!
Last edited by Larry Cole; 12-29-2007 at 11:45 AM. Reason: Wanted to add some more.
Larry Cole is offline   Reply With Quote
Old 12-29-2007, 12:02 PM   #2 (permalink)
Cant give you any definitive answer ... Recall seeing forum posted problems similar to what you describe that were caused by the neutral safety switch ... which is located in the engine compartment, in the vicinity of the transmission case. ...The GEN 3 wiring diagram might provide additional information with regard to potential problem/solutions related to the NSS.
see p. 205 of Gen 3 wiring diagram ... part P1 ... Neutral Start Switch
please provide engine type and transmission type ... automatic?
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 12-29-2007, 12:43 PM   #3 (permalink)
It's a 4 cylinder automatic.
Old 12-29-2007, 08:45 PM   #4 (permalink)
Mad Scientist
2wickedtoyz's Avatar
Gameroom cash: $248601
iTrader Score: 9 reviews
View 2wickedtoyz's Photo Gallery
hey man i'm in miramar and i've dealt with this many times there are 2 philips screws holding the ign switch in place. and the plug is white. i'll pm you my number and i could give you a step by step while i'm on my car...........
[url]http://www.cardomain.com/id/wickedtoyz[url]
Camry Wagon Crew
2wickedtoyz is offline   Reply With Quote
Help me to understand timing PoR2GeEzCamry General Discussion 1 11-02-2007 11:14 PM
Gas Mileage stumpfoot Pre-88 Toyota Pickup/Hilux 17 08-03-2007 01:42 AM
96 Camry wagon needs! CWhittemore@hot Car parts for trade or wanted parts 0 07-16-2007 04:32 PM
Help, Will 01 Solara rims on my 96 camry wagon? quigs Solara 0 02-26-2005 10:53 PM
01 solara rims on a 96 camry wagon? quigs Solara 1 02-26-2005 09:39 PM
