Please Help! Key stuck in ignition - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-29-2007, 12:48 PM   #1 (permalink)
View icemike's Photo Gallery
I have a 93 Camry, about 150k, 4 cyl. The ignition tumbler was worn out, and the key wouldnt turn to acc. I dropped the steering column, had to drill out the bracket holding the tumbler, drilled out the release pin in the tumbler and installed a new one. Now everything is reinstalled the key turns fine but when I want to remove the key I cant! The only way the key will come out is if I disconnect the battery, than it removes like it should. Im stumped, thanks for your time.
icemike is offline   Reply With Quote
FYI- How Transponder Keys Work Phi Audio, Video, and Security - Tech 3 01-02-2009 08:44 PM
Key broke in ignition of 1990 corolla. applesandwich 6th Generation (1988-1992) 3 06-06-2008 01:31 PM
Trouble Codes abew330 3rd & 4th Generation (1992–1996 & 1997–2001) 9 02-09-2007 01:04 PM
Help: Ignition Key in New 06 Camry wont turn zainali 5th & 6th Generation (2002-2006 & 2007-2011) 7 09-27-2005 06:24 AM
