Auto Unlock in Park - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-29-2007, 03:13 PM   #1 (permalink)
View underpowered's Photo Gallery
4th Generation Auto Unlock in Park
Hi, just wondering if there is a way to have the doors automatically unlock once the the car is shifted from drive to park.
Thanks
underpowered is offline   Reply With Quote
Old 12-29-2007, 05:58 PM   #2 (permalink)
This could be done ... Basically, all you do when you push the unlock switch is to pulse a control terminal on the doorlock control IC, so that it is momentarily grounded. You would have to install a relay, and come up with a custom circuit design so that when the neutral start switch was shifted to Park, sequencing through the Reverse gear select position, a momentary ground pulse would be generated. You would also probably want a toggle switch to optionally disable the relay. Your custom circuit should only activate the unlock pulse when going from Reverse to Park, and not from Park to Reverse ... Altogether, not a major project, but not just hooking some wires together.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
20r Engine Rebuild From Hell! nwdetectorist Off Topic 6 10-20-2007 09:19 AM
Got Trick by BC Auto. Speed300 General Lexus Discussion 7 06-19-2006 02:30 PM
Faster 0-60 time = RSX Auto or tC Auto? cman2000 General Discussion 25 05-23-2005 02:40 PM
Washington Auto Accessory Expo inzanesrt4 Regional Meetings and Events 1 05-18-2005 09:44 PM
Manual vs auto question Bakemono 2nd Generation (2005+) 7 03-28-2005 12:46 AM
