anyone have a squeaking compressor? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-29-2007, 09:39 PM   #1 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
for the past 2 weeks now, my AC compressor has been squeaking. its pretty noticeable when the car is idling and the compressor is not running, but goes away if the defrost is on. what would cause the squeak from the pulley when its not running? any way to fix this?
Old 12-30-2007, 09:17 AM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Since it is noticeable only when the compressor is off (when you turn on the defrost it automatically turns on the AC) I tend to lean towards the AC clutch mechanism. If it were the AC bearing you'd hear it when the AC was on. If it were something with the belt or other pulleys you'd hear it whether the AC was on or off.
Just a thought,
Kep
Old 12-31-2007, 10:11 PM   #3 (permalink)
ghettosled's Avatar
dammit, just took the car out and the noise has gotten worse and now the noise doesnt change when the compressor kicks on. my guess its the bearings in the pulley. any way to access them to possibly grease them?
Old 01-01-2008, 08:51 PM   #4 (permalink)
Mad Scientist
2wickedtoyz's Avatar
Gameroom cash: $248601
iTrader Score: 9 reviews
View 2wickedtoyz's Photo Gallery
wish i could help better but mine makes a knocking noise so it the bearings yours might just need some silicone lube on it
[url]http://www.cardomain.com/id/wickedtoyz[url]
Camry Wagon Crew
2wickedtoyz is offline   Reply With Quote
Old 01-02-2008, 12:01 AM   #5 (permalink)
View davemac2's Photo Gallery
You need to replace the clutch bearing most likely. I think these are sealed bearings, so you can't lube them. Even if you could, it would not help for long. For your compressor (10PA17C):
bearing ($35): http://www.apairinc.com/detail.asp?part=440-948
clutch plate puller tool: ($15) http://www.tooldesk.net/ATD_3610.html
You will need some sort of puller to pull the bearing off once you pull the clutch plate and pulley.
You should double check your compressor model (Nippondenso) to be sure.
dave mc
davemac2 is offline   Reply With Quote
Old 01-02-2008, 09:05 AM   #6 (permalink)
ghettosled's Avatar
thank you so much especially for the links. ill double check the compressor model and consult the manual and see how to remove the bearing.
A/C Compressor Question fj55mike 1st & 2nd Generation (1983–1986 & 1987-1991) 1 08-09-2006 01:55 PM
1999 2WD Tacoma Coil Spring Compressor bill70 Hardcore Tech and Competition 2 09-23-2005 03:02 PM
'89 Camry A/C Compressor Not Running 89DLXV6 1st & 2nd Generation (1983–1986 & 1987-1991) 7 08-27-2005 03:09 PM
1994 Camry compressor installation? prwood 3rd & 4th Generation (1992–1996 & 1997–2001) 3 08-19-2005 08:05 AM
ct26 compressor question silverstreakin Hardcore Tech and Competition 5 08-02-2005 08:31 AM
