TRD RSB Does Not Fit!!! Extremely Furious! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-30-2007, 03:12 PM   #1 (permalink)
TRDSleeper's Avatar
View TRDSleeper's Photo Gallery
4th Generation TRD RSB Does Not Fit!!! Extremely Furious!
I bought a TRD rear sway bar about 2 months ago and didn't have the time to install it until yesterday. I spent a ridiculous 6 hours trying to get the stock sway bar out and putting the TRD one in. From reading the DIY threads it shouldn't have taken me so long. To me it feels like the TRD bar is about a half-inch shorter than it should be and the included bushing is too thick. My brother and I kept pulling and pushing trying to line up the mounting bracket to the screw hole but it was impossible. Maybe the bar I got was a bad one that just happened to pass quality control at the factory. The one I got was listed in the TRD catalog for a 99-03 Solara. Isn't that the one that members on this forum are using? Please let me know how you got your RSB on. In the mean time I put my stock sway bar back on so I can drive my car. Thanks.
Here is the right side. It's bolted up correctly, but the bar is obviously rubbing against the strut
The left side is off aligned by 1/2 inch. I tried to force the mount to the left but it just wouldn't go. Even if I could, I think it's too much stress on it to drive safely. The bar doesn't rub the strut in this side.
TRDSleeper is offline   Reply With Quote
Old 12-30-2007, 03:34 PM   #2 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
did you order the correct TRD RSB? for the 1st Gen Solara?
if so, have you been in any rear-end collisions?
the bar shouldnt be off, and i doubt TRD made it wrong .... are you using Gen 4 Bushings, Mounts, Endlinks?
have you set it up for Track Setting or Street Setting? maybe one side is not adjusted properly?
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 12-30-2007, 04:14 PM   #3 (permalink)
TRDSleeper's Avatar
4th Generation
^ Yes, I believe I ordered the correct RSB. TRD parts #PTR06-06990-10.
I have never been in any collision at all. I have a gen 4.5 and I used the factory end links, mounts, and the TRD bushings that were included with the sway bar. I couldn't even get the bar mounted correctly in the first place so I didn't get a chance to install the endlinks to the track or street setting.
Old 12-30-2007, 04:19 PM   #4 (permalink)
Experience>Post Count
View MIC0417's Photo Gallery
Japan
Just move the side that is rubbing the strut to the left while in the mount then the other one will be aligned
MIC0417 is offline   Reply With Quote
Old 12-30-2007, 04:21 PM   #5 (permalink)
felonyr301's Avatar
View felonyr301's Photo Gallery
Ohh this is getting me worried, hopefully I don't run into this problem too. Hope you figured out whats the deal with yours!!! I know if this shit happened to me I want to break something, doing all the work to find out it doesn't fit damn it sucks.
felonyr301 is offline   Reply With Quote
Old 12-30-2007, 04:37 PM   #6 (permalink)
TRDSleeper's Avatar
4th Generation
My brother and I tried pushing and pulling all we can and it wasn't easy to move the bar to the left because bushing on the right side was not allowing us to move it any further. The bushing was already starting to hit the corner of the bar and can't be forced beyond that. If there was just another half-inch of length, then it will fit perfectly.
Old 12-30-2007, 05:19 PM   #7 (permalink)
Venom_5's Avatar
youll have no problems felonyr301, dont worry
OP: have you tried to remove the TRD RSB completely, and put it back in using a different order of parts
ie: if you tried to mount to the right side endlink first, then the right side bushing mount, try both bushing mounts first and then the endlinks or vice versa
Old 12-30-2007, 06:55 PM   #8 (permalink)
93 240sx SR Hatch
DAMON's Avatar
iTrader Score: 36 reviews
View DAMON's Photo Gallery
mine was kind of tricky to line up correctly and I remember it was a pain to get the bushing brackets to line up... as long as its the right bar, I doubt there is any issue with it being manufactured wrong. Try to see if you can take the other side apart and bolt it up to the side it wont reach right now- I had to bolt and unbolt mine several times to get everything to line up correctly. It can be a real pain for sure, but keep at it- itll go on eventually.
94 Camry (Beater) 99 Solara (Totaled) 93 240SX (Current)
DAMON is offline   Reply With Quote
Old 12-30-2007, 07:27 PM   #9 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
thats the right part # for sure. got any more pics of the area under there?
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 12-31-2007, 02:42 PM   #10 (permalink)
TRDSleeper's Avatar
4th Generation
^ The other pictures I took shows the same two corner of the sway bar. I didn't take any pictures of the center of the bar. I think I will jack up my car and try to reinstall the TRD sway bar again. I'll try what the other members have suggested so far. Thanks.
Old 12-31-2007, 04:11 PM   #11 (permalink)
Venom_5's Avatar
one more thing - did you have BOTH sides jacked up in the rear during the install?
Old 12-31-2007, 11:25 PM   #12 (permalink)
TRDSleeper's Avatar
4th Generation
^ Yes, I did jack both sides of the car up when I was installing the RSB. I used a 3-ton jack in the center and two 2-ton jack stands on the sides. I'll let everyone know if I achieve success in my project.
Old 12-31-2007, 11:44 PM   #13 (permalink)
View kendallKICKASS's Photo Gallery
the TRD sway bars are a pain and mine didnt fit at all but u can go to andysautosport and they have the perfect ones
kendallKICKASS is offline   Reply With Quote
Old 01-01-2008, 10:08 AM   #14 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Lay the OEM bar and the TRD bar side by side and see if there is a real difference.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 01-01-2008, 03:28 PM   #15 (permalink)
TRDSleeper's Avatar
4th Generation
SUCCESS!!!! HAHA! I finally managed to install my TRD RSB. I decided to go under my car again and try once more to get the bar on. I really had to push and pull the bar to align the two mounts up. The TRD polyurethane bushings were thick and extremely resistant to any force. I guess that's good for holding the bar in place once it's bolted on. I probably scratched the bar at a hundred different places so it might rust in the future but at least I was able to get it on. I actually managed to get the bar on by midnight on New Years Day so I was extremely happy. Happy New Year to everyone!
Some pics of the RSB after installation:
Since it was a total hell for me to install my RSB. I'm including some pics of what I did to make the bar fit so others won't have as much problem as I did.
I found that screwing the RSB on the endlinks first help hold the bar up so it's easier to work with. I didn't have to worry about holding the bar up as I am trying to bolt on the mount at the same time. It was also easier to bolt the rear screw on the mount first, then bolt the front screw.
The orientation of the bar also plays a big factor in aligning the screw hole for the front bolt. With the bar down, the mount and screw hole are very off aligned.
But when you raise the bar up, they align much better. At this point I used pliers to push the hook up into the rectangular hole. Once this was done, the front bolt went on very easily.
Here's how I jacked up the car. I highly recommend getting a creeper since it greatly helped me get around under my car.
TRD or Whiteline RSB jmp0126 3rd & 4th Generation (1992–1996 & 1997–2001) 3 07-24-2007 07:25 AM
Does anyone know if the Scion Tc TRD supercharger will fit the RAV4? haa21 RAV4 Forum 5 07-06-2006 11:50 AM
Will a Solara TRD muffler fit?!!!!!!!!! Live1521 Solara 20 07-30-2003 10:38 PM
Can this TRD Spring fit... Eniffey Camry & Solara Lounge 2 03-10-2003 10:16 PM
Will TRD Camry kit fit Solara??? Jay Solara 0 07-02-2002 01:00 AM
