ATF for a '96 V6 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-31-2007, 07:14 AM   #1 (permalink)
TN User
View argh's Photo Gallery
3rd Generation ATF for a '96 V6
A few questions about the correct transmission fluid for a '96 V6...
1) Is Dexron III the correct stuff to use? Toyota brand?
2) Four quarts enough for the both the transmission and differential?
3) At 113,600 miles, should the filter be replaced?
Finally, did I leave anything out for this transmission drain/refill job?
The only record I have of the last transmission/diff fluid job was @ 45,000 miles..
argh is offline   Reply With Quote
Old 12-31-2007, 08:28 AM   #2 (permalink)
I'm not sure, but you can look at the end of the trans dip stick, and in very faint letters, if it says
TYPE T-IV, then you should use Toyota OEM T-IV ATF. This seems to be specific to the V6 automatic version. I know the T-IV is used in the Gen 5 V6, but I'm not completely sure about Gen 3 and Gen 4. .... I would not use the DEX III fluid, if your dip stick says T-IV. ... I just made that mistake recently, and am doing several drain/refills to try to rectify the situation. The quantity that will drain out ... transmission plus differential, is about 3.6 qts. .... I think the T-IV fluid has different characteristics than the DEX III. I'm not sure about the long term effects, though.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
96 V6 transmission / differential fluid – separate or shared? PatrixUSA 3rd & 4th Generation (1992–1996 & 1997–2001) 5 11-23-2009 07:50 PM
Oil light on '96 XLE V6. Ideas? Siper2 3rd & 4th Generation (1992–1996 & 1997–2001) 9 01-02-2007 05:30 PM
Toyota Tranny fluid only? netranger6 2nd Generation (2005+) 11 10-11-2005 01:26 PM
thinking bout buying a camry for my next car 96 up 4clyinder or v6 . cool car guy 3rd & 4th Generation (1992–1996 & 1997–2001) 20 04-30-2005 06:59 PM
2002 camry V6 vs. 96 2dr camry V6 wheels17 5th & 6th Generation (2002-2006 & 2007-2011) 2 10-23-2004 10:59 PM
