Smoke under hood near Radiator - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-31-2007, 08:35 PM   #1 (permalink)
View desi's Photo Gallery
3rd Generation Smoke under hood near Radiator
Hi I have 1993 camry V6 Automatic with 130k miles. Just recently I started to see smoke coming from underneath my car's hood near radiator. Radiator is 1.5 years old and is filled with coolant. Not sure where to look to start troubleshooting. Any help is appreciated.
desi is offline   Reply With Quote
Old 12-31-2007, 08:41 PM   #2 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
are you sure its coming from the radiator?
have you checked oil levels? there isnt oil dripping onto any part of the exhaust, because that can cause grey/white smoke as well
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 12-31-2007, 08:47 PM   #3 (permalink)
3rd Generation
Smoke is not coming from the radiator. It is coming from some pipe near/under the radiator. I did have some fluid leak problem. Not sure if the smoke is coming due to fluid leak. What type of testing I need to do to find that out?
Old 12-31-2007, 08:51 PM   #4 (permalink)
Import Tuner
Spartan0536's Avatar
View Spartan0536's Photo Gallery
3rd Generation
after installing my new header I had some leakage with smoke coming out like you do, its more than likely an exhaust leak, try to check you header to downpipe connection or as suggested before to check your oil levels and check for a leak. I would guess its nothing too serious yet so as long as the problem is either a seal gone bad or your exhaust manifold leaking gasses.
Spartan0536 is offline   Reply With Quote
Radiator Question: No leak, no smoke, but level keeps dropping unkit 3rd & 4th Generation (1992–1996 & 1997–2001) 7 11-01-2007 03:44 PM
Replaced Radiator - what is this wire?! PDXterra Celica Forum 8 08-13-2005 07:43 PM
carbon fiber hood Group Buy Jonsblckhwk Yaris, Vitz and Echo Forum 9 03-01-2005 02:09 PM
Radiator started to show some cracking... Jokeplayer Camry & Solara Lounge 5 11-05-2003 01:40 AM
