Originally Posted by hbasavar
My radiator cap has worn out and sure the coolant is not pressurized. Would this cause the high cylinder temps with higher NOX emissions?
The coolant temp is still half way in the middle.
Difficult to say for sure. You might have two separate problems going on.
One is excessive hydrocarbon emission ... not burning fuel efficiently.
Two, is excessive NOx emission.
The loose radiator cap could be the cause of the excessive hydrocarbon results ... due to lower engine temp ... in the vicinity of the cylinders.
Not sure what is going on with the dash gauge. I wouldn't trust it completely. It only measures the temperature at one point in the coolant system.
With the sealed radiator cap functioning properly, the coolant system pressure is about 30 psi absolute. With a defective/loose radiator cap, the system pressure is about 15 psi absolute. At 30 psi, the normal condition, you have a higher coolant temperature ... and more complete combustion and better efficiency. ...
At 15 psi, you will not be burning your fuel as efficiently as at 30 psi.
With the coolant system not being sealed, you will be gradually loosing water as a result of evaporation. Eventually, you will have enough coolant loss that your engine will overheat... probably in traffic during rush hour.
So, make a point of buying a new radiator cap, refill coolant reservoir with correct 50/50 antifreeze/distilled water mix.
Hope that the loose radiator cap was not a long term situation .... which might have created a problem.
Not sure about the NOx emissions.... I would investigate the EGR valve for carbon build up ... This is a frequent complaint reported on the forum posts. I think you can check the movement of the flexible diaphragm with the engine running ... just push it up and see if the engine returns to normal after a second. It might be a good idea to disassemble the EGR and see if you can clean up some of the accumulated carbon ... You're talking about several years of engine operation with a 93 model. There might to be a DIY sticky on this posted at the top of the forum page. ... There ought to be.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
