both low beams went out @ same time - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-01-2008, 04:35 PM   #1 (permalink)
View ebbob's Photo Gallery
Question both low beams went out @ same time
I own a '99 Toyota Solara and it seems that both low beams went out at the same time. Is this possible or could it be the Dimmer Relay? The high beams and fog lights both work along with the balance of the lights on the vehicle. HELP
ebbob is offline   Reply With Quote
Old 01-01-2008, 05:03 PM   #2 (permalink)
xtremeskier97's Avatar
Gameroom cash: $198580
View xtremeskier97's Photo Gallery
Seems awfully odd that they went at the same time. You could always use a voltmeter to check the light sockets to see if they are getting power.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 01-01-2008, 05:18 PM   #3 (permalink)
4th Gen Camry Owner
View kpszar's Photo Gallery
Also check the fuses, if that does not work^^^^ Odd how they both went out at the same time.
kpszar is offline   Reply With Quote
Old 01-01-2008, 05:49 PM   #4 (permalink)
Dimmer Relay sounds like a good place to start ....
If you can find one at a salvage yard, you can confirm your guess ...
Also check the relay socket contacts for corrosion or oxidation ... invest in a spray can of electrical contact cleaner.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Overtime Vs Comp-time Tommy Off Topic 15 06-19-2007 02:44 AM
Consumer Reports on HID Phi General Discussion 28 01-17-2007 09:23 PM
2007 avalon hid low beams to low dave p 3rd Generation (2005-2012) 7 11-09-2006 05:41 AM
Whats the closest to HID ? sunny_8 3rd Generation (2005-2012) 75 08-03-2006 02:27 PM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 11:53 PM
