Bad Alternator??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-02-2008, 12:46 AM   #1 (permalink)
MOBB's Avatar
View MOBB's Photo Gallery
4th Generation Bad Alternator???
I own a 01' XLE V6 with about 186k's on it. When i am driving at night and come to a complete stop the interior dash lights dim (mainly the dash gauges), the dimming isn't very noticeable. As soon as I accelerate the interior lights go back to there normal state. The same thing also happens with the fan, i can hear the difference in the fan output while accelerating.
The car also has an abnormal starting problem, sometimes it'll start firm and other times it will just feel like it it'll die and just barley start I sometimes have to hit gas to get it to start.
What are these the symptoms of? I thought it was the battery, so i got it replaced for an AC delco one but the problems still persists. Are these the signs of a bad alternator what should I be looking for??
MOBB is offline   Reply With Quote
Old 01-02-2008, 10:50 AM   #2 (permalink)
Darkside Cut Me!!!
Gameroom cash: $127223
View Hajoca's Photo Gallery
Normal. do a search.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 01-02-2008, 11:15 AM   #3 (permalink)
Might be dirty or oxidized alternator connections.
First disconnect the negative battery terminal from the battery.
Get a small, fine wire brush, remove the alternator plug and clean it with the brush. Also get a spray can of electrical contact cleaner and spray both alternator plug and socket .... On the alternator there is a ground wire connection ... a threaded bolt and nut as I recall. Clean these and spray with contact cleaner... snug up nut on bolt, but don't over tighten.
It is important for electrical connections to have bright, shiny surfaces... If they are dirty or loose, the electrical current can't get from one side to the other of a plug or terminal. ... Sometimes moisture is a factor, or maybe road salt, or just a lot of road miles.
Starter problem might be due to internal contact plate within the starter ... probably have to rebuild or get a new one. Not sure about starter relay... I would guess problem is actually in the starter, where it handles the high magnitude motor current. ... Might be worth removing the starter cable terminals and cleaning the connections .... remove negative battery cable first though.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 01-02-2008, 12:06 PM   #4 (permalink)
MOBB's Avatar
Will try to clean everything before taking into the shop, thanks for the info!!
Old 01-02-2008, 12:56 PM   #5 (permalink)
See link here ... post #21:
Trouble starting 99 Camry
Old 01-02-2008, 01:51 PM   #6 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Clean the battery terminals too. Make sure that they are snug.
Kep
toyota pickup 91 alternator died, need help for replacement advise magus123 89-95 Toyota Pickup/Hilux 16 06-15-2010 04:06 PM
What gives you a bad case of gas? xpeed Off Topic 41 09-25-2007 12:22 AM
Bad Alternator Bearing??? Weaves_Taco 2nd Generation (2005+) 5 07-11-2007 01:54 PM
toyota pickup 91 alternator died, need help for replacement advise magus123 89-95 Toyota Pickup/Hilux 2 05-24-2007 05:11 PM
Alternator bad? 89 Camry shuluke 1st & 2nd Generation (1983–1986 & 1987-1991) 6 09-11-2003 11:00 PM
