intermittent directionals - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-02-2008, 08:35 AM   #1 (permalink)
View EEGTECH's Photo Gallery
Was wondering if anyone had any idea why my turn signals work on the morning ride to work, shutting off about 1/2 way to work, (12 miles) sits in a parking lot during the day and work 1/2 the ride home then quit again. The fuse is fine and all other lights work?
Thanks!
EEGTECH is offline   Reply With Quote
Old 01-02-2008, 08:50 AM   #2 (permalink)
Just a guess ... Your turn signal flasher might be aging. It is located under driver dash ... upper left kick panel ... p. 31 of Gen 4 wiring diagram, part T6. Maybe just remove, clean socket and plug connectors, and then replace. If that doesn't do anything then get a new one.
Also, you might check your battery/charging system (load test, alternator) and clean the battery cable terminals. Any other unusual symptoms, such as dimming headlights?
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 01-02-2008, 08:53 AM   #3 (permalink)
Thanks a million! Will do!
Dawn
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 12:49 PM
Trouble Codes abew330 3rd & 4th Generation (1992–1996 & 1997–2001) 9 02-09-2007 02:04 PM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 11:53 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 01:49 PM
