I can't budge the bulb for the back marker light! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-02-2008, 04:27 PM   #1 (permalink)
View MeAndMyCamry's Photo Gallery
My Camry is a 2001 sedan (U.S. built) and try as I might, I CANNOT pop that bulb out of the socket. Judging by the replacement bulb, I don't think it's soldered in. It's just tiny and I can't good grip on it. Does anyone have any neat tricks to help me?
The saga goes on!
D
MeAndMyCamry is offline   Reply With Quote
Old 01-02-2008, 05:08 PM   #2 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
the bulb is stuck?
Old 01-02-2008, 05:58 PM   #3 (permalink)
Either that or just very hard to pull out of the socket. I just don't want to break it in either case.
Old 01-02-2008, 06:49 PM   #4 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Must wiggle and twist, use a rubber glove for grip.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 01-02-2008, 08:16 PM   #5 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
You do know you have to push slightly in and twist, right?
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 01-02-2008, 10:37 PM   #6 (permalink)
View toyomoho's Photo Gallery
Check the owners manual for type of bulb; push, twist and lock or bayonet push-in. Might be a little corrosion on the end of the bulb.
Old 01-03-2008, 11:06 AM   #7 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Which bulb are you trying to remove? A shot of WD40 or the like might help.
Kep
Old 01-05-2008, 06:48 PM   #8 (permalink)
The rubber glove did the trick
I just needed something to help me get a grip. Thanks for all the help.
side marker bulb - how to replace?? fenbach RAV4 Forum 5 12-30-2007 07:23 PM
PIAA Xtreme White Bulbs PSyCHo-RaGe 5th & 6th Generation (2002-2006 & 2007-2011) 30 05-25-2007 08:16 PM
05 corolla tail light bulb oem mismatch-any one else had this issue? ekimwons Archived Corolla threads 3 06-10-2006 08:43 AM
Blacked out Side Marker light... mystickid Camry & Solara Lounge 1 11-29-2005 05:20 PM
