There have been several posts about a problem with the wire loom in the vicinity of the trunk hinge. You might take a close look .... open up ... the loom wrapping and see if you can trace the green wires with red stripe ... which go to the individual brake lights. Look for broken wires ... insulation gaps or anything unusual.
Possibility that one of the brake light wires is shorting out with a tail light wire ... solid green ... which would have voltage present whenever the lights are on.
What you're saying is that only one of the brake lights stays on ... not all of them?
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
