camshaft subgear - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-03-2008, 10:00 AM   #1 (permalink)
View onemorerep's Photo Gallery
camshaft subgear
Working on a 97 5sfe. I rebuilt it about two years ago, but have been experiencing oil consumption. Finally the HG blew. Did a pressure check and 3 & 4 were down to nothing. Pulled the engine to replace the headgasket and find the pesky oil problem.
As I am taking off the head, I went to put the service bolt into the exhaust subgear, but it seems to be out of alignment with the main gear. Would this subgear misalignment cause a firing problem and thus my oil consumption? Is there any special trick to realigning the subgear and main after I take the exhaust camshaft out?
onemorerep is offline   Reply With Quote
Old 01-03-2008, 10:32 AM   #2 (permalink)
Excuse my impertinence ... but which instruction set are you using?
Are you going by the I4 Mechanical Section ... p. 37-38 ... online repair manual?
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 01-03-2008, 11:35 AM   #3 (permalink)
engineer in training
Gameroom cash: $145055
There may be two sets of markers on the exhaust cam, I ran into a problem reinstalling the camshafts in my Celica and got the timing way off. This will only cause the engine to not start however, it will not cause your oiling problem.
Old 01-03-2008, 03:00 PM   #4 (permalink)
using the tsm eg1 50-51 for the camshaft removal.
removed head and checked head gasket...no apparent leak.
removed piston 3 & 4 which had problems. the alignment of the rings looks bad which I suspect caused blowby and the oil usage.
Camshaft subgear and main is still a question...how do you realign them so you can get the service bolt through as in TSM.
Changing V6 Timing Belt Pics and the $270 Coil Connector marc780 5th & 6th Generation (2002-2006 & 2007-2011) 81 04-09-2012 07:26 AM
Replacing V6 camshaft seals toytrain13 Camry & Solara Lounge 3 03-07-2007 05:55 PM
OBD Code Camshaft Sensor, but There Isn't One! Jeff_M_PA Camry & Solara Lounge 9 10-19-2006 06:12 PM
Should I mess with the Camshaft pulley? kamrhee 3rd & 4th Generation (1992–1996 & 1997–2001) 2 09-19-2006 09:25 AM
1MZ-FE camshaft weirdness m4663 Hardcore Tech and Competition 16 11-28-2005 02:28 AM
