Aftermarket Catalytic Converter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-03-2008, 08:10 PM   #1 (permalink)
View camlex's Photo Gallery
Hello,
I have a 1997 ES300, which is the same as the v6 camry. I replaced the aftermarket cat. converter three times and I'm having some problems with my Check Engine light. I'm wondering if anybody has replaced their original converter with the aftermarket catalytic converter? I'd like to know the manufacturer and the model number. I did use magnaflow and it did not work. Thank you in advance.
camlex is offline   Reply With Quote
Old 01-04-2008, 12:29 AM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
what code are you throwing? and if its the post-cat o2 sensor, have you tried changing the sensor instead of the cat?
HaHa
Old 01-04-2008, 07:01 AM   #3 (permalink)
code: P0420
I have replaced front 2 O2 sensors six months ago and after cat. O2 sensor with after market cat.
he tried three different(Model) cat. from magnaflow.
Old 01-04-2008, 11:30 AM   #4 (permalink)
TN Pussy Man
problem could be in the aftermarket post-cat o2 sensor
there have been many problems reported with using non-oem o2 sensors in general, whereas pretty much nobody has reported problems with magnaflow cats
I myself am running a high performance magnaflow cat
HaHa
Old 01-04-2008, 11:37 AM   #5 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
i dont have the v6 motor, but i the converter i have on my car is from catco. i too got the 0420 code, but since the new cat the code hasnt been back.
on a side note, i heard that high performance cats have more of a tendency to throw codes because being high performance an d most likely straight through, they dont filter as well.
Old 01-04-2008, 05:11 PM   #6 (permalink)
View freestylez's Photo Gallery
same code keeps popping up for me too, i replaced my cat in October and started getting the code in Dec...could be the O2 sensors setting it off, not really sure, this code is a pain in the ass
2000 CAMRY CE
freestylez is offline   Reply With Quote
Old 01-04-2008, 06:20 PM   #7 (permalink)
FYI
my two front O2 sensors and my other one after cat. O2 sensors are from toyota.
Two front were changed 6-7 months ago and after cat O2 sensor was changed with Cat. con.
Old 01-05-2008, 11:01 PM   #8 (permalink)
CEL disappear byself. I thought you have to reset.
Hope never come back again.
Thanks,
Old 01-05-2008, 11:08 PM   #9 (permalink)
Toyota Technician
View bigdaddymak20's Photo Gallery
4th Generation
Sidenote: all OBDII cars have to have a scan tool to erase codes immediately. Some codes are programed to see 30 plus engine cycles to reset a code. Hope this helps.
bigdaddymak20 is offline   Reply With Quote
Old 01-06-2008, 08:29 AM   #10 (permalink)
Thanks,
"Some codes are programed to see 30 plus engine cycles to reset a code."
Please explain. I don't get it.
Old 01-07-2008, 11:02 AM   #11 (permalink)
so far no CEL.
Old 01-07-2008, 02:01 PM   #12 (permalink)
TN Pussy Man
Originally Posted by camlex View Post
Thanks,
it means that some codes will reset only after the car has been turned on and off a certain number of times as well as driven a certain amount of distance as well
HaHa
Old 01-07-2008, 07:13 PM   #13 (permalink)
Toyota Technician
4th Generation
Engine cycle means that the computer sees the engine go from cold to fully warmed up.
Catalytic converter compatibility? Peacefrog Yaris, Vitz and Echo Forum 11 03-05-2009 11:21 AM
catalytic Converter TEC 1st Generation (1995-1999) 2 12-03-2007 09:18 PM
My catalytic converter was stolen!!! AVL92CAMRY 3rd & 4th Generation (1992–1996 & 1997–2001) 44 10-20-2007 09:36 PM
Matrix catalytic converter going bad, costs $1300 joemaniaci 1st Generation (2003-2008) 13 10-11-2006 08:10 PM
catalytic converter recommendations? DailyDriveCamry Camry & Solara Lounge 0 10-09-2004 09:45 AM
