Unusual voltage at startup
I've looked up and down for anything similar to this issue. Dealer has observed the issue but could not identify a cause. Car is a 2000 XLE V6 (1MZ-FE) about 100K miles.
For the first 3-4 minutes after a cold startup, my car's voltage rises and falls at a very consistent rate of about twice a second. Then, all at once, it smooths out (no transition between the fluctuations and "smooth" voltage). It does not seem like a loose ground/connection issue, because the fluctuation is so perfectly consistent, and I've looked at and jiggled everything searching for a loose connection. At it quits exactly the same way each time. Also, it doesn't matter what RPM the engine is running at, if the car is moving or parked, etc. It is always the same.
So, this car is like a UFO calling home for 4 minutes in the morning, because the headlights, interior lights, dash, all pulse at the very consistent 2 hz rate (not completely on and off, more of a brief flicker).
I have changed the battery and alternator (with a refurbished Denso alternator) but neither stopped the "flickering."
My only guess (based on what could possibly be turning on and off at startup) is that the car has CA emissions, could it just be the A/F sensors drawing a ton of power at startup? Add this to the cold northeast (we are really far away from CA) and lights on in the morning -- could it just be too much draw on the alternator? If that is it, I guess I'm not too worried about it but it is still annoying.
