Eyelids, build thread, no 56k - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-05-2008, 10:21 AM   #1 (permalink)
Super deluxe Happy member
Quicksilver300's Avatar
View Quicksilver300's Photo Gallery
Been wanting to make these for a while, since at least in my state, they take the no tape on lights to include eyelids. So vinyl was out of the question.
So, I'll use fiberglass, I decided to make them only for the headlights and not the side lights, due to the complexity it would cause, so these will be small eyelids.
First I've got to remove the head lights, which I found in one of the sticky threads
Then I taped the lights, you must tape the whole light. I used blue tape to delineate where the eyelid will be cut afterwards.
Once taped, I wetted the tape with epoxy and layed down two successive layer of fiberglass cloth.
From there, I went ahead and started doing some work at filling in low spots and imperfections.
Then I removed the eyelids, which was pretty hard, you just have to work them off the lights slowly. I used a knife to slowly pry them off.
From here, I have to finish the work needed to prep the eyelids for final paint, which will involve some more putty, some more resin here and there and then paint. I'll get back to you all, this was what I finished last night
If you insist on getting your way often enough, pretty soon you won't have to argue with anyone about it anymore
Quicksilver300 is offline   Reply With Quote
Old 01-05-2008, 11:04 AM   #2 (permalink)
Sleepin zZzzzz
360glitch's Avatar
View 360glitch's Photo Gallery
Cool project, I'm anxious to see the results.
'01 Avalon XLS - Project Log
'92 Eagle Talon TSi AWD - Project Log
360glitch is offline   Reply With Quote
Old 01-05-2008, 02:00 PM   #3 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
cool man, i loved having eyelids on my gen3.5 it looked meaner even if it wasnt intimidating in the least.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 01-05-2008, 02:16 PM   #4 (permalink)
View BaByBoiGsxR's Photo Gallery
Talking
hey bro, you did you sand down the fiberglass after it dried up before painting it? Very crucial man. I don't have any custom fiberglass parts on the car, but from what my buddies and pros at the shops do, it'll come out looking really really smooth and clean at the end.
p.s.- use the fine grit automotive sand paper.
(thought that it might be a helpful hint)
BaByBoiGsxR
BaByBoiGsxR is offline   Reply With Quote
Old 01-05-2008, 03:19 PM   #5 (permalink)
TN's Nikon Expert?
prnc_chrmng's Avatar
Gameroom cash: $490868
View prnc_chrmng's Photo Gallery
man, seeing someone else do it almost makes me want to go out and finish mine.
one of the things i didn the second time was use some mounting tape along the bottom edge of the eyelid ao it would have a small grove to sit it them i mount it.
Originally Posted by 98tercel_girlie
This thread needs more porn, less blah blah
prnc_chrmng is offline   Reply With Quote
Old 01-05-2008, 04:19 PM   #6 (permalink)
thx for the comments here they are, I think theyre the sex, well the sex below an nsx.
top view
First a close up........p.s. for the next reply I hope you have a good connection
Old 01-05-2008, 04:25 PM   #7 (permalink)
I first sanded with 220, moved up to 400, applied glazing putting, (edit; forgot I threw some primer on a few times to judge how smooth it was) sanded again with 400, and again and then black primer on both sides, sanded with 1000, then laid down two coats of dark red followed by two coats of a lighter shade, followed by 2 coats of clear, sound about right. Luckily I know just as much about cars as I do boats... So I know glass.
some daylight
edit for the 14th time, forgot to add, theyre affixed by 3M double sided tape and just stuck to the top of the lens.
some in a parking lot with sleet
Old 01-05-2008, 05:08 PM   #8 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
they look good .... did u block out much light output, or is it hardly noticeable?
oh, and i do think eyelids look better on the gen 3.5, just because they would flow with the shape of the headlights better towards the center of the car
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 01-05-2008, 05:28 PM   #9 (permalink)
xet
View xet's Photo Gallery
looks good, i would prefer a less sharp angle but still good job
1998 camry xle v6 *no longer mine*
2005 G35 coupe 6mt
xet is offline   Reply With Quote
Old 01-05-2008, 05:29 PM   #10 (permalink)
I didnt notice any loss and they do block all the light. eyelids that show through look bad., just an fyi.
As for a 3.5, I dont have one so.....these look damn fine to me.
Old 01-05-2008, 05:33 PM   #11 (permalink)
I went through many options using photoshop, but came to this one. I dont know really how I'd change em.
Heck here's a challenge. I'll throw up a pic of the car without them and see what you guys come up with. Since they are just double sided taped on and made of fiberglass, I could change em or remake em, if someone comes up with something better
Old 01-05-2008, 07:11 PM   #12 (permalink)
Go camry goooooo
DrewsCam's Avatar
Gameroom cash: $184780
View DrewsCam's Photo Gallery
great job, i made eyelids for my gen 4 and they didnt turn out half as well, instead on tape i extended the eyelid to the back of the light and
made a mounting tab on the frame of the car
11/19/2007 Gen 6 08 Camry SE.
Rockland Toyota / Scion Showdown 4.0 Sept 26th
DrewsCam is offline   Reply With Quote
Old 01-05-2008, 07:14 PM   #13 (permalink)
The laziest around
LazyAccent's Avatar
View LazyAccent's Photo Gallery
Great job they look great
Can you do the dansing and raise the roof?
LazyAccent is offline   Reply With Quote
Old 01-05-2008, 07:54 PM   #14 (permalink)
No Fat Bitches
iTrader Score: 10 reviews
View PtBaller's Photo Gallery
Nice work. Which part of NY are you from?
^ Volk Racing CE28s 19x8.5/8 for sale
PtBaller is offline   Reply With Quote
Old 01-05-2008, 07:58 PM   #15 (permalink)
thanks guys
by the Binghamton area originally from poughkeepsie
My turn for a Wax show-off thread (56k no way) 06Sport Show & Share 17 06-04-2007 03:54 PM
how to thread cddallara 2nd Generation (2005+) 18 04-11-2007 07:09 PM
The "My other car is a" Thread (56k b-ware!) Camry_rider Off Topic 28 08-04-2003 07:54 PM
Pretty awesome thread over at MR2 baord Wraith Camry & Solara Lounge 1 08-17-2002 03:03 AM
