windshield washer can not squirt - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-05-2008, 10:51 AM   #1 (permalink)
View carknight's Photo Gallery
The washer tank is full.The fluid is not frozen.And I can hear the sound from the circuit when I operate the washer.But no liquid come out.Anyone has suggestions to share with,I really appreciate.
carknight is offline   Reply With Quote
Old 01-05-2008, 11:13 AM   #2 (permalink)
Pissed
View Camryamnesty's Photo Gallery
can you hear the pump? pull the hose off on your hood, blow some compressed air through the hose, i dont think cans have enough pressure, but you dont want too much pressure cuz it can pop all the hoses off. Blow until air is coming out of the nozzles then it should be fine.
Camryamnesty is offline   Reply With Quote
Old 01-05-2008, 12:57 PM   #3 (permalink)
Super deluxe Happy member
Quicksilver300's Avatar
View Quicksilver300's Photo Gallery
if that doesnt work try cleaning out the nozzles with a pin. I've never had a problem that wasnt fixed just by doing this.
If you insist on getting your way often enough, pretty soon you won't have to argue with anyone about it anymore
Quicksilver300 is offline   Reply With Quote
Old 01-05-2008, 03:24 PM   #4 (permalink)
Strum's Avatar
View Strum's Photo Gallery
I've had to take a pin and clean out the end of the nozzles, however it is strange that no fluid is coming out of either nozzle. Make sure the tubing is connected under the hood. Mine stopped working once and I found that the hose going from the passenger side to the drivers side was disconnected and due to loss of pressure it prevented fluid from coming out of either nozzle.
Strum is offline   Reply With Quote
Windshield washer problem jc27 3rd & 4th Generation (1992–1996 & 1997–2001) 7 01-28-2007 08:52 AM
windshield washer and coolant 2020 1st Generation (2003-2008) 3 10-16-2006 05:28 PM
87 Camry Wagon, Windshield Washer Resivoir(s) curtisz 1st & 2nd Generation (1983–1986 & 1987-1991) 1 01-02-2006 01:14 AM
windshield washer system dutchcrunch Archived Corolla threads 3 08-04-2005 08:55 PM
windshield washer lights grapefury Camry & Solara Lounge 17 05-28-2003 10:49 PM
