Hello-
My 2000 Camry driver's side door lock isn't working properly. I've searched around, but haven't had much success with help. The lock behaves completely normally except when invoked electrically. Symptoms:
1) Keyless entry locks/unlocks all doors but driver's
2) Double key-turn in passenger door locks/unlocks all doors but driver's
3) Single key-turn in driver's door locks/unlocks drivers door
4) Double key-turn in driver's door locks/unlocks all doors (but the driver's door is already locked or unlocked from the first turn of that
mechanical double key-turn)
So it looks like the problem is electrical rather than mechanical. I've pulled the paneling off and I'm sitting in front of the door right now. There's some plastic covering the door and I see lots of wires, and it's rather evident which ones connect to the driver's door, but I can't find a wiring diagram anywhere. Nor do I have a continuity tester on me. I can go pick one up, but I thought I'd post first to see if anyone had some advice. So, on that note, any advice?
Thanks! -J
PS. Here's a picture what I'm looking at, if that helps!
