exhaust camshaft install - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-05-2008, 08:26 PM   #1 (permalink)
View onemorerep's Photo Gallery
Rebuilding my 5FSE and having trouble getting the exhaust camshaft to properly sit into the bearing journal.
Followed the TSM and installed the intake camshaft. I get the timing mark alignment with the intake cam...dots line up, intake camshaft 10 degree BTDC, etc.
However after following the TSM, it seems that the exhaust camshaft doesnt lay into the journals due to the intake camshaft's gear teeth. The camshaft is flat (not rocking) but is 1/8" from sitting in journals. I have moved the intake camshaft CW and CCW but the exhaust camshaft just doesnt lay into all the journals. I dont want to force it and casue a crack in the head or camshaft. Is this normal and when I tighten it down the caps in the proper sequence will it seat into the journals?
onemorerep is offline   Reply With Quote
Old 01-05-2008, 10:52 PM   #2 (permalink)
Toyota Technician
View bigdaddymak20's Photo Gallery
4th Generation
One of the cams has a place to put a bolt so it doesn't unspring. If you didn't that would explain it not sitting flat. Let me know
bigdaddymak20 is offline   Reply With Quote
Old 01-06-2008, 08:01 AM   #3 (permalink)
yes, I have the service bolt in the exhaust camshaft through the manin and subgear.
Old 01-06-2008, 06:41 PM   #4 (permalink)
Pissed
View Camryamnesty's Photo Gallery
Well, are you sure its not sitting right just because one of the lobes on the cam is pointing straight down on a lifter? If it is, you should be able to just tighten it down and it will open that valve.
Camryamnesty is offline   Reply With Quote
Exhaust Question! and car alarm install question Spitfire 3rd & 4th Generation (1992–1996 & 1997–2001) 9 11-02-2007 06:40 PM
Toyota avalon 2007 time belt diagram drhusein 3rd Generation (2005-2012) 6 10-30-2007 07:35 PM
So.Cal Fujitsubo Install Day (1/29/05) jim@streetimage Celica Forum 0 01-12-2005 07:36 PM
Cheap exhaust trick Naito Hardcore Tech and Competition 23 08-03-2003 08:44 PM
