Help with Heated seats and rear defrost ?
OK I tricked you....
Im asking about a 1995 Avalon, but since they are so similar to the Camry in many areas I thought I would ask here too.
First problem is the rear defrost will not come on. The fuse is not blown and I hear a click in the fuse area of the dash when I turn it on. Any common points of failure I could check on this?
Also, I have a heated seat fuse in the fusebox, but cannot figure out how to turn on the seat heat. The manual indicates there's a switch for it in the door but no such switch exists. Would that indicate maybe it comes on automatically with another function, or am I out of luck? I have the front bench seat, not sure if that matters.
N
