Oil Leak..from where? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-07-2008, 02:48 PM   #1 (permalink)
Super deluxe Happy member
Quicksilver300's Avatar
View Quicksilver300's Photo Gallery
well, that sums it up, I'm trying to figure out what would leak oil on to my fuel rail and intake manifold. I thought my leak was from the pan, but today(since it's 60 degrees out) I was poking around and noticed a lot of what I would descibe as sludge on the intake. Any Ideas? Once we get into the actual engine, I'm pretty lost on the subject.
I'll go take some pictures of this.
If you insist on getting your way often enough, pretty soon you won't have to argue with anyone about it anymore
Quicksilver300 is offline   Reply With Quote
Old 01-07-2008, 03:04 PM   #2 (permalink)
View toyomoho's Photo Gallery
The valve cover gasket often leaks, have you tried retorquing the spark plug tube nuts? Sludge as in oil and dirt or water?
Old 01-07-2008, 03:28 PM   #3 (permalink)
definitely oil and dirt. I just checked my oil level too, and I was down about 3/4 of a liter. I hope it's something simple like the valve cover.
first over of the engine
little closer
Straight down from the top of the intake.
that's about it. I'm going to go check and see if any of the tube nuts are loose. Hard to take pictures, I was hoping I could use the camera as a probe of sorts...no too much shit in there
Old 01-07-2008, 05:15 PM   #4 (permalink)
turns out, they were loose. Hope that's all it was. At first I couldn't think of how to tighten nuts that big, but then I remembered I have a 18" long adjustable wrench in my trunk. First 2 nuts 1/2 a turn loose, third was fine and the forth turned almost 3/4.
There's nothing else that would leak oil back there? Maybe injectors?
Old 01-07-2008, 06:18 PM   #5 (permalink)
View moocow's Photo Gallery
Um, I just started a thread yesterday for an oil leak. I too thought it was the gasket, until I saw your pics I went to take a look at my camry. Turns out my intake is covered in black goo as well. What tube nuts are you talking about? Are they the spark plugs themselfs? Also would I find the long wrench at autozone, pepboys, etc? Is it a socket wrench extension?
99 Toyo Camry I4, Adire Shiva 12'' Sub, SUBZero Mfg. vented box @ 1.5 cubic feet, Profile sub amp (200rms), Hifonics Falcon 2chan 90rms(x2), CDT CL61a components, Alpine headunit.
moocow is offline   Reply With Quote
Old 01-07-2008, 07:45 PM   #6 (permalink)
You pull the spark plug wires out and under the rubber is the nuts. The thing is, the nuts are huge, 30mm to be exact. You could use a socket, but it wont be cheap. I just happen to have the huge adjustable wrench because my father bought it to take the propeller off his Trawler . I borrowed a long time ago and subsequently it was in my trunk. Probably water pump pliers would work, I'm not quite sure what you're SUPPOSED to do here. Maybe you could borrow one from autozone or advanced auto.
Found a neat pic
apparently you're supposed to tighten them like you tighten an oil filter. Once the nut is snug you turn it another 30 degrees. I think I might go get a new gasket and do this over. Wish I knew this before hand, but then I've never seen valve cover bults like this before. At the same time then I'd know for sure whether this was the problem, might pick up some paint too
Old 01-07-2008, 08:07 PM   #7 (permalink)
The grime in the photos is typical oil and dirt mixed together, nothing unusual.
If this does not do the trick replacing the valve cover gasket is easy enough and again pretty typical as the engine ages.
Try Sears for a large diameter socket to fit the tube nuts or use a large wrench.
Old 01-07-2008, 08:15 PM   #8 (permalink)
like I said I just didnt realize I had the tool needed all this time. Probably would have pulled the valve cover before out of curiosity. I always go after stuff like this because I worry about something leaking on the belts, namely the timing belt. ok, that and I have the dirtiest motor on tn. Thank you though, at least it's nothing out of the ordinary.
Old 01-07-2008, 11:16 PM   #9 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
17 ft-lbs is the torque spec, i do believe ...
and they are 30mm nuts (i actually bought a socket for them since i dont like adjustable wrenches)
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 01-08-2008, 12:07 AM   #10 (permalink)
lol, I've got to take a picture of this wrench, not of the ordinary. I kept it in the car as my beat down stick, however if you hit someone with it anywhere above the waist, theyd be doa. A long time ago, I said well if I have to use it, I swing at the knees unless I'm staring down a barrel.
Old 01-08-2008, 02:07 PM   #11 (permalink)
Today, I got everything done but change the valve cover gasket. I just didnt feel like going there. So I changed about 2.5qts of A/T fluid, first time I've ever done the fluid before in my life. Amazingly easy but took a long time to drain. Also washed the engine with simple green. It worked, but not like I would have liked. I think the reality is, it's never going to look good, seen too many miles and too much salt and red clay roads.
before
after
yeah I cant tell the difference either from the pictures. It does look better, but I need like a pressure washer to get the block, it's filthy.
Old 01-20-2008, 03:29 PM   #12 (permalink)
Um, I attempted to remove my valve cover, I removed the nuts, the tubing, and tried to pry it with a putty knife. No go. I used a mallet to bang on it several times... still no go. I took a pic... is this removing the tube nuts? Did I forget to take anything else off? The thing won't budge
Old 01-20-2008, 03:45 PM   #13 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
your using a rubber mallet right? bang it some more, on the sides to get it to move. if that fails, bang harder!!!
WhiteRabbit is offline   Reply With Quote
Old 01-20-2008, 03:56 PM   #14 (permalink)
A buddy of mine said to watch it a bit, as I might crack it, but I think that would only happen w/ a steel hammer.
Old 01-20-2008, 11:34 PM   #15 (permalink)
Ok guys, I finally managed to get it off, the gasket looked good... ehhh however now I didn't have a new gasket on hand. I wiped down the gasket as best as possible... on both the engine side and the cover. Then put the RTV silicone on the 8 points that the hayes manual says. Put the cover back on and replaced the nuts and the washers under them. Soo... I guess its not the valve cover after all.
Change your own oil in your V6 camry (DIY, pic intensive) 95WhiteCamry 3rd & 4th Generation (1992–1996 & 1997–2001) 97 05-20-2010 11:02 PM
Oil leak - Help! bavula 3rd & 4th Generation (1992–1996 & 1997–2001) 6 04-22-2007 02:53 PM
Oil Leak when Accelerating??? renmike 3rd & 4th Generation (1992–1996 & 1997–2001) 6 10-08-2006 08:41 PM
oil leak! help! matrix37495 Tercel, Paseo, Starlet, and Sera Forum 7 05-28-2005 10:49 PM
Mobil1 5w-30 Synthetic and my 2002 Corolla??? gadawg Archived Corolla threads 6 01-26-2004 04:39 AM
