Bolt size intake plenum ground wire - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-07-2008, 07:54 PM   #1 (permalink)
View 300kmi97camry's Photo Gallery
Can anyone please tell me the size of the bolt of the ground wire on the fire wall side of the intake plenum. The wire next to the passenger side plenum brace/bracket. I was replacing the rear vavle cover gasket-not a task I ever want to do again and I dropped the bolt and can't retrieve it. I know it has a 10mm head but how long is it? It's a v6 1997 camry LE
Thanks
300kmi97camry is offline   Reply With Quote
Old 01-07-2008, 10:53 PM   #2 (permalink)
Toyota Technician
View bigdaddymak20's Photo Gallery
4th Generation
Dont worry about the head size. Only thing that matters is the thread size and length. It will be metric ie 10x1.25. Go to a parts store and get different sizes and lengths and with trial and error you will find the one that works. You can take back the ones that dont work.
bigdaddymak20 is offline   Reply With Quote
Old 01-09-2008, 02:51 PM   #3 (permalink)
View mleray24's Photo Gallery
I have a 1997 Lexus ES300 V6 (part for part identical except for engine cover) and the bolt is 12 diameter x 8mm height. bigdaddymak20's advice is correct regarding thread, but that is the height if it helps.
mleray24 is offline   Reply With Quote
Old 01-12-2008, 09:36 AM   #4 (permalink)
Thanks guys, I'll try to get to the parts store today and get some bolts. In the mean time I have the ground wire pinched between the plenum bracket and plenum. The car runs fine but now my AT pan is leaking. Will prolly try to do that next weekend.
ground wire question JHATTEN 89-95 Toyota Pickup/Hilux 4 11-12-2007 07:54 PM
Basic Amp Install Instructions Phi Audio, Video, and Security - Tech 11 04-06-2005 02:25 PM
Ground Wire Kit?? Piran21 General Discussion 3 03-22-2004 04:51 AM
what size wire from amp to ground? crazy_camry Audio, Video, and Security - Tech 3 11-07-2003 02:16 PM
Subwoofer Install? CamrySpeaksJL Audio, Video, and Security - Tech 17 02-07-2003 08:33 AM
