well i went to pep boys and picked up a new distrubutor, rotor, wires and coil for about $125 total.
started out by following the manual recommendations and checked the resistance on my plug wires. Came out around 15K. checked my new wires and they came out at 1K, so i decided i would change the wires. Still wouldn't start.
Next decided i'd check the distributor. It wasn't in great shape, with lots of corrosion.
the rotor wasn't in the greatest of shape either
so i replaced them both.
I checked the resistance of the coil and the primary was 0.9 and should be around 0.5. I was thinking of replacing it, but i check the resistance on the replacement part and it was pretty much the same, so decided i would only change the distributor, the rotor and the wires, a total of $70 in parts. Put it back together and voila! it started and runs great once again!
thanks for all the input
