Brakes are a tough gig. Sometimes it's just the luck of the draw.
I've tried them all.............and I mean.......THEM AAAALLLLLLLLLLLL!!!!!!!!!!!!!!
OEM pads, cheap pads, ceramic pads, middle grade pads....you name it, I've tried it.
Same thing for rotors. Good, cheap, middle, oem.......been there, done that. OEM is good, but typically the "better/best" at your local auto parts store are good rotors too.
My recommendation to you would be to remove the pads and sand them a bit (evenly) to break the surface. (Something rough like 80grit or 60 grit sand paper)
Then, when you reassemble, I would highly recommend the blue goop.(
http://www.permatex.com/documents/td...tive/80729.pdf.) Key to using it is to put some between the shims & pads, but here's how....... After you've smeared it on the back of the pads.......wait about 20-30 minutes to let it set. (tacky & rubbery is ideal) Then......push & smush the shims onto the back of the pad.
On top of that.....be sure to smear brake grease all over the back of the shim. (I also smear it all over the contact areas of the calipers. That's smearing it all over the face of the caliper piston as well as the inside of the forked outer side of the caliper as well. And then install the gooped up, lubed up pads back into their new, lubricated homes..........("Go to your home........are you too good for you home???")
If you've done all of the above that's your best chance of quiet brakes. If they squeal, they squeal. Sure, oem rotors might have helped, but I've had plenty of oem's squeal too.
