Center Console??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-08-2008, 09:10 AM   #1 (permalink)
megamac83's Avatar
View megamac83's Photo Gallery
4th Generation Center Console???
Hey I need help taking out the center console, I can't find the clips or nuts that will allow me to remove them. PLEASE HELP!!!
megamac83 is offline   Reply With Quote
Old 01-08-2008, 09:27 AM   #2 (permalink)
If you download the Gen 4 repair manual and look in the Body pdf section, there are some diagrams on p. 72, and a few instructions on p. 76.
It looks like you take out the top plate ... the center console upper panel ... first, then take out the rear console box, and then the front console box. The bolt locations should be shown in the diagram on p. 72.
The only thing I would watch out for is the air bag connectors ... over by the glove compartment.
It looks like the diagram letters for the bolts and screws are coded to correspond to the chart on p. 74.
Not sure if there is anything else that would be 'not obvious' ..... just looking at the pdfs.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
$2 fix for center console squeak FlopShot 5th & 6th Generation (2002-2006 & 2007-2011) 5 01-20-2011 07:43 PM
2001 Center Console Latch Needed maspc 2nd Generation (2000-2004) 2 07-21-2009 06:08 PM
Solution: Rattle/Squeak in center console of 07 Camry ToyotaCarFan 5th & 6th Generation (2002-2006 & 2007-2011) 6 11-16-2006 01:41 PM
Gen4 Center console MoldySpore 3rd & 4th Generation (1992–1996 & 1997–2001) 2 03-24-2005 03:10 PM
How do you get the center console out? (92 Camry) cmjohnson 3rd & 4th Generation (1992–1996 & 1997–2001) 6 12-01-2003 01:22 AM
