Rattling sound on bumpy roads - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-08-2008, 11:10 AM   #1 (permalink)
audax's Avatar
View audax's Photo Gallery
USA Rattling sound on bumpy roads
Re.: Camry 1997, 82K miles, 4-cyl
I noticed a rattling sounds coming from the front, when I drive on bumpy roads. I suspected the struts, but a friend of mine check them and declared them ok. Any idea what I should check?
TIA,
Audax
audax is offline   Reply With Quote
Old 01-08-2008, 01:07 PM   #2 (permalink)
JvR
JvR's Avatar
View JvR's Photo Gallery
cv joints?
Do you hear the sound also when you make corners
JvR is offline   Reply With Quote
Old 01-08-2008, 01:37 PM   #3 (permalink)
audax's Avatar
Originally Posted by JvR View Post
cv joints?
No, I do not.
Audax
Old 01-08-2008, 01:43 PM   #4 (permalink)
Gameroom cash: $303055
Do a search for "strut mounts" on this forum. The upper strut mounts are a known trouble area on the 97-99 Camrys. This has been covered numerous times. Other areas to check are the swaybar end links and the swaybar bushings. Jack up the car and inspect these items.
Mike
Old 01-08-2008, 04:31 PM   #5 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $906927
iTrader Score: 59 reviews
^^^do as Mike says!!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 01-08-2008, 07:26 PM   #6 (permalink)
Radio, this is Unit 91...
eurohazard's Avatar
View eurohazard's Photo Gallery
^^^3rd that! I'd bet money it's the strut mounts. A "visible" inspection won't declare bad strut mounts. It's a sound that's unique and fun!
1993 Camry LE 5SFE AT, 2006 Nissan Armada LE 4x4, 1971 Cadillac Coupe DeVille "pimp juice"
Toys: 2007 Coachmen 19FLB, 2007 Regal 1900 V6
I'm the biggest boss thatchu seen thus far! Baby, that's muh wi'zzard!
eurohazard is offline   Reply With Quote
Old 01-08-2008, 08:24 PM   #7 (permalink)
felonyr301's Avatar
View felonyr301's Photo Gallery
It's either the strut mount and if not then most likely the endlink or bushings or both of it!!!
Normally rattling is from the swaybar area (bushings, endlinks) and the strut mounts make more of an clunk noise.
felonyr301 is offline   Reply With Quote
Old 01-09-2008, 12:14 AM   #8 (permalink)
View wahed3001's Photo Gallery
I had the same problem that was driving me crazy (annoying!!). I had the upper strut mount nut tightened with an impact wrench and it went away! I also sprayed some silicone grease in there to reduce friction.
wahed3001 is offline   Reply With Quote
Old 01-10-2008, 11:42 AM   #9 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Not as fancy as struts and mounts but verify that your car keys aren't rattling against the steering wheel cowling.
Kep
Old 01-11-2008, 04:57 PM   #10 (permalink)
megamac83's Avatar
View megamac83's Photo Gallery
I would check the sway bar bushing along with the sway bar link for play!!
megamac83 is offline   Reply With Quote
Old 01-13-2008, 03:42 PM   #11 (permalink)
daveart's Avatar
View daveart's Photo Gallery
its your links and mably bushings for the sway bar
daveart is offline   Reply With Quote
Old 01-13-2008, 09:39 PM   #12 (permalink)
View MarktheShark's Photo Gallery
I had this same problem. Looked at everything including struts. Turned out it was the hood bouncing up and down. Check that out.
MarktheShark is offline   Reply With Quote
Very interesting... NH05TACOMA 2nd Generation (2005+) 52 04-08-2008 06:20 PM
Harsh 2-1 Downshift while in 'S' Mode Mistabullet 5th & 6th Generation (2002-2006 & 2007-2011) 20 03-19-2007 08:01 AM
Trouble Codes abew330 3rd & 4th Generation (1992–1996 & 1997–2001) 9 02-09-2007 01:04 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
