start by removing the trim bezal to get full access to the the lighter.
disconnect the connectors.
remove the nut and there will be a washer behind it. that washer you will keep. there is a second washer which is bigger in diameter is between the bottom tabs.
once you pry the tabs open take out the washer. put the tabs together and re-install the lighter
if need more help, send me a PM and i'll do my best to help you out.
The Camry is a car that I can rip out someone's pride, stab it, beat it, and completely bash their egos, and it's so ridiculous that the person comes back with a hysterical laugh... ROFL They got trainlengthed by a Camry that in their mind, was a 18 sec car.
R.I.P. Black95Camry..
yeah. i got it off your old thread. and i figure im doing it so mind as well snap some pictures. its a simple fix that almost anyone can do.. much props goes to midnightmach.
^^^ not sure what you are saying but when i plug any power source to it, there would be no power. this is just a simple, cheap way of fixing it. but use it at your OWN risk.
Originally Posted by xtremeskier97
Ok..first thing's first...its DIY..not DYI. And second...what exactly are you doing here? Was something broke and you are fixing it, or what?
Just trying to find out what all this is about.
my bad... it was too early in the morning for me. yes i guess you can say it was broken since it didnt have any power coming through the lighter when the fuse was still good.
okay cool that was a great idea ... we are all learning from each other
..my bad... it was too early in the morning for me. yes i guess you can say it was broken since it didnt have any power coming through the lighter when the fuse was still good.
Ok cool...just didnt know what to take it for.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
but is it possible that the the power in it is not exactly what it should be cause it seems that it makes my LG GPS go crazy.
maybe it was juste because of the cold and a long week on my back seat
I Had the same problem on a saturn and my camry,
it turned out that the wire that is crimped to the 2 metal washers
was not making contact. i re-crimped the wire connections and
checked with an ohm meter that it was making contact.
works great now, the wire seems to be a sacrificial part to keep the socket
from melting the dashboard, if too much current is drawn through the socket
where the two metal plates, one connecting to the input wiring, one connected to the cigarette lighter housing, were not making contact because of the washer in between. Obviously when it was first put in, there was contact, but for some reason the washer became non-conductive. It turns out that both my cigarette lighter outlets stopped working around the same time, when I was doing some testing for work, powering our devices through the cigarette lighter. Apparently, pulling close to the 110W limit over long periods of time causes an electrostatic potential to be created between the two plates, across the washer. If there's moisture in the air (i.e. humidity), that washer will become oxidized and not make good contact between the two plates. Similar to that elementary school science experiment where you apply a voltage across a small piece of copper in (tap) water and get the resultant electroplating.
Anyhow, I thought I would respond and give a little bit of the reason I've found for why this happens. Coincidentally, I fixed mine by simply applying a solder bridge across the two plates, bypassing the washer. This way I didn't have to pry the plates apart.
Depending on which problem you are having with the cigarette lighter, this may fix it. If you disassemble the center console, remove the cigarette lighter plug, look on the back, you should see the washer. If it's oxidized like mine was, it will have a greenish tint. You may also check for oxidation by using a multimeter and checking the resistance between the two plates. If there is a high resistance (kOhms or MOhms), this diy should fix your problem. If you measure close to 0 ohms (or don't see visible oxidation), this diy MAY NOT help you.
LazyAccent~
I reread your 1st post, and I'd suggest you first check your fuses if you haven't done so already. You said that the clock and radio still work fine, but on my Camry, these are on different fuses from the cigarette lighter and power outlet. My cig lighter and power outlet fuses are located behind the little change holder left of the steering wheel. Just a suggestion...
