front panel bulbs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-09-2008, 03:45 PM   #1 (permalink)
View nanywrd's Photo Gallery
USA front panel bulbs
hey friends , the small bulbs which light up the front panel where you have the fan and the heater knob. there are two tiny bulbs. how much do they actually cost? are they not available at autozone or any store like that.
because i asked at the toyota dealers , they are asking for whopping 14 $. thats too much for those small little tiny bulbs.
can you suggest me a place where i can get cheaper ones?
nany
nanywrd is offline   Reply With Quote
Old 01-10-2008, 10:40 AM   #2 (permalink)
Check Out That Camry!!!!
CAMRYTUNER20's Avatar
View CAMRYTUNER20's Photo Gallery
4th Generation
you should just go ahead and do the led conversion while youre in therehttp://superbrightleds.com/mini-wedge.html you need the #74 wedge i do believe
KEEP THE PIMP HAND STRONG!
CAMRYTUNER20 is offline   Reply With Quote
Old 01-10-2008, 04:07 PM   #3 (permalink)
Gameroom cash: $303055
You don't say what year or generation your Camry is and your profile doesn't show it. I just changed one of those out on a friend's 2001 Camry and 74 bulbs worked perfectly. They are available just about anywhere, including Walmart. You will have to remove the green sleeve from the old bulb and transfer it to the new bilb.
Mike
Old 01-10-2008, 06:27 PM   #4 (permalink)
sorry bro !! mine is a 96 camry, i did go to a autozone and got a pair for 3.99 atleast 10 bucks cheaper from the toyota dealer . is that ok??? they are a;ll 12 volts but what about the wattage? the ones i purchased from the autozone they are a little different in size, very minute change but more or less they are the same size only. they are 5 watt bulbs . would that be fine.
please advise..
thanks in advance
Old 01-11-2008, 02:07 PM   #5 (permalink)
please advise..
thanks in advance
The attached link is a complete aftermarket bulb guide list for your car. Notice at the bottom it says something like misc. instrument panel bulbs and lists 194's (which it's not) and 74's. If you got 74's at Autozone, I would say give them a try. It doesn't take long to change them out and if the bulb out indicator on the dash is not on, that tells me that those bulbs are not monitored by the system like headlights, tailgihts and all the parking lights; so it probably won't do any harm.
http://www.sylvania.com/ConsumerProd...RG-Results.htm
Mike
Old 01-12-2008, 10:03 AM   #6 (permalink)
View CarDrivinHick's Photo Gallery
Yeah, for my '97 Camry, I went to AutoZone, they didn't have them, called the dealership, they told me that they were $6.50 a piece, and that their was 3 bulbs. Went to the dealership, $4.50 a piece, actually only 2 bulbs. Only go to your dealer for the bulbs!
CarDrivinHick is offline   Reply With Quote
Rear Diff oil blues.... pdx 2nd Generation (2005+) 214 07-18-2010 05:00 PM
Silverstar "Ultra" fredster34 5th & 6th Generation (2002-2006 & 2007-2011) 35 07-22-2007 11:55 AM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
Whiteline MA70 Front/Rear Adjustable Swaybar GroupBuy!! raptorracing Supporting Vendor Sales 30 04-27-2007 03:27 AM
